WRVS4400N v2 firmware - where is it?
mail
Where do I find firmware updates for WRVS4400N v2?
I have just set one up with VPN to a WRVS4400N v1 (maybe v1.1). that works.
But the Wireless clients does not work very good.
Sometimes they cannot connect, other times they work fine.
I have no LAN-clients except for a printer with static IP.
I can see there have been problems with v1 and v1.1 when there is no LAN DHCP clients. Is it the same problem here?
I suppose there is a chance that a new firmware could help me.
My current firmware is: v1.00.09-etsi
15 Replies 15
Moderator
Level 6
Level 6
Thanks for your post. This page might be helpful: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=282414016 Please let me know if this was useful or if you need further support.
Cisco Moderation Team
Please verify if the firmware exists before you links!! The only update i can see is IPS signatures.
mail@fshcomputer.dk,
Could you please let me know if are seeing the same issues from my earlier posts
https://www.myciscocommunity.com/message/5647#5647
I spent more than hour with tech support and got several firmware releases which did not work. In case something works for you, Would appreciate if you could post to this forum
Where's new firmware?
I buy this router I have problems.. WLAN disconnected.
petrkosec
VPN don't work correctly. I have v2 and firmware 1.00.09. where is new firmware?
1.00.09 is the latest firmware for WRVS4400N V2. What kind of VPN issue did you encounter?
I have Linksys QickVPN 1.2.11 and pem certificate on client.
When I connecting to VPN - Connecting - Activating Policy - Verifying Network - The remote gateway is not responding. Do you want to wait?
When you saw the "Do you want to wait?" pop-up message, were you be able to access the resources in the remote LAN, e.g. web server or ftp server? The pop-up simply indicated that the QuickVPN client cannot ping the QuickVPN router's LAN IP, which is usually blocked by firewalls installed on the QuickVPN client. This is not a defect of the router.
jarharpe
That is the latest greatest firmware out for v2 wrvs4400n
Where it is possible to download itself 1.00.09?
the latest FW can be found here, but alas, there is no GW in here...
http://www.cisco.com/en/US/products/ps9931/index.html
I will keep looking. bear with me...
I just checked for someone and saw it available now.  Version 2.0.0.7 (WRVS4400Nv2-fw-2.0.0.7-K9.img) inside that ZIP as well as a version 40 IPS file....
  Nice that's it's finally here.. are there release notes to describe what's been addressed, etc .. Saw one for the signature file, but all I se is the firmware image .. Readme would also be helpful to determine if this release requires complete factory reset, etc ...  Thanks
The release notes will be posted here, and in this case are lagging a little.  I was told it is to be posted soon...
http://www.cisco.com/en/US/products/ps9923/prod_release_notes_list.html
