Call Home on Nexus 5548up switch
russjstewart
Hello all,
We are trying to setup Cisco's Call Home on 5548up switches.
We have managed to get the email component working and are able to get a full-txt email using the callhome test command.
We are configuring this to monitor interface up/down syslog events as the switches connect our services environment.
I have been trying to get CallHome to trigger an email notification by shut/no shut of a port with no success.
Should alerts trigger on an admin. shut/no shut of a port?
Have I missed anything in the configuration below?
Below is the output of a show run callhome all command on a configured 5548 switch:
5548_switch# sh run callhome all
!Command: show running-config callhome all
!Time: Tue Feb 19 13:56:11 2019
version 7.1(4)N1(1)
callhome
switch-priority 7
email-contact xxxxxxxx@xxxxxxxxx.xxx.xxx.au
phone-contact +613-XXXX-XXXX
streetaddress 200 Xx. Xxxxxxxxx St. Xxxxxxxxxx
destination-profile PDC_5548_1
destination-profile PDC_5548_1 format full-txt
destination-profile PDC_5548_1 transport-method email
no destination-profile PDC_5548_1 transport-method http
destination-profile PDC_5548_1 message-size 2500000
destination-profile PDC_5548_1 message-level 2
destination-profile full_txt
destination-profile full_txt format full-txt
destination-profile full_txt transport-method email
no destination-profile full_txt transport-method http
destination-profile full_txt message-size 2500000
destination-profile full_txt message-level 0
destination-profile short_txt
destination-profile short_txt format short-txt
destination-profile short_txt transport-method email
no destination-profile short_txt transport-method http
destination-profile short_txt message-size 4000
destination-profile short_txt message-level 0
destination-profile CiscoTAC-1 transport-method email
no destination-profile CiscoTAC-1 transport-method http
destination-profile CiscoTAC-1 message-size 5000000
destination-profile CiscoTAC-1 message-level 0
destination-profile PDC_5548_1 email-addr xxxxxxxx@xxxxxxxxx.xxx.xxx.au
destination-profile PDC_5548_1 alert-group all
destination-profile CiscoTAC-1 alert-group cisco-tac
destination-profile full_txt alert-group all
destination-profile short_txt alert-group all
transport email smtp-server xxxxxxxxxxxx.xxxxxxxxxx.xxx.xxx.au port 25 use-vrf default
transport email from xxxxxxxxxx@xxxxxxxxx.xxx.xxx.au
transport http use-vrf default
no transport http proxy enable
transport email smtp-server xxxxxxxxxx.xxxxxxxxx.xxx.xxx.au port 25 use-vrf default
enable
duplicate-message throttle
periodic-inventory notification
periodic-inventory notification interval 7
periodic-inventory notification timeofday 08:00
5548_switch#
Many thanks.
Justin Sprake
The Call-home capability actually does not create notification for a variety of administrative operations on the device, including shut/no shut commands. The extent of the call-home capability will depend on the device platform/IOS itself. The below document regards Smart Call Home notification and SR creation policies, but also contains each Call-home alert as well:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/smart_call_home/user_guides/MonitoringDetails.pdf
For port status notifications, you will likely need to implement some TCL scripting.
