Welcome to the Smart Call Home Community!
Our online forum for Smart Call Home customers to share, learn, and collaborate on Smart Call Home related topics. We encourage you to ask questions of Cisco experts, start a discussion, or share ideas and insight.
Smart Call Home enabled devices perform proactive diagnostics on their own components to provide real-time alerts and remediation advice when an issue is detected. An embedded support feature available on a broad range of Cisco products, it is provided at no additional cost with an active Smart Net Total Care Service, SP Base, Unified Computing Support Service, or Mission Critical Support Service contract for the designated products.
This Community will provide you with an overview about Cisco Smart Call Home features and how these features are embedded in a wide range of Cisco products to help your network. Smart Call Home provides higher network availability and support service quality.
1402
Highlighted
Beginner
Unable to send Smart Call Home messages via email
Hello everyone,
We have started deploying SCH using HTTP reporting back to a TG for some of our devices. But due to the number of quirks across so many different versions of hardware/software, we are looking into email reporting - hoping that will let us use the same method across all devices.
I am testing on a Nexus 5672UP running 7.1(4)N1(1). Running the command 'callhome test inventory' - debugging on the firewall shows no traffic being sent at all. HTTP alerts work, but we have to use the default profile "CiscoTAC-1" for some reason. I've noticed that on some other Nexus devices as well. If I telnet to the SMTP server on port 25 I get a response.
Here are the configs:
callhome
contract-id XXXXXXX
email-contact XXXXXXX
phone-contact XXXXXXX
streetaddress XXXXXXX
destination-profile CiscoTAC-1 message-size 2500000
destination-profile test
destination-profile test format XML
destination-profile test message-size 2500000
destination-profile test email-addr XXXXXXX
destination-profile test alert-group All
transport email smtp-server XXXXXXX port 25
transport email from XXXXXXX
transport email reply-to XXXXXXX
enable
periodic-inventory notification interval 30
Here is the debug output from "debug callhome all". I changed my SMTP server IP to "$smtpServerIp" in the output:
callhome: Src: 0x00000101/54670 Dst: 0x00000101/0 ID: 0x08ED5A58 Size: 2740 [REQ] Opc: 2157 (MTS_OPC_CALLHOME_TEST) RR: 0x08ED5A58 HA_SEQNO: 0x00000000 TS: 0xF9B5747131C28 REJ:0 SYNC:1 OPTIONS:0x0
<<< HEX DATA REMOVED >>>
callhome: In can_process_message for alert inventory
callhome: alert inventory exists in the alert table
callhome: Updated the message sent count for alert inventory to 18
callhome: filling in time field with 2017-02-02 07:19:09 GMT-07:00
callhome: filling in subtype, type fields with inventory
callhome: inventory message
callhome: appending type nvp
callhome: appending subtype nvp
callhome: filling in the header list
callhome: filling up the chassis list
callhome: filling up the main body list
callhome: filling up the fru list
callhome: Entering function do_event_correlation
callhome: getting dest profiles for alert group test
callhome: getting dest profiles for alert group cisco-tac
callhome: dest_profile_id full_txt added to final list
callhome: dest_profile_id short_txt added to final list
callhome: dest_profile_id test added to final list
callhome: dest_profile_id CiscoTAC-1 added to final list
callhome: Value of is_storage_vdc is #0#
callhome: event rule id value : #nexus_cli_command#
callhome: event rule id value : #alert_group#
callhome: event rule id value : #level#
callhome: event rule id value : #mds_cli_command#
callhome: Applying the event rule for destination profile full_txt
callhome: alert group for profile : full_txt is : all
callhome: Applying the event rule for destination profile short_txt
callhome: alert group for profile : short_txt is : all
callhome: Applying the event rule for destination profile test
callhome: alert group for profile : test is : all
callhome: Applying the event rule for destination profile CiscoTAC-1
callhome: Exiting function do_event_correlation
callhome: Entering build_event_notification_payload
callhome: key : Name value : 85344_crsw01.den03
callhome: key : EventTime value : 2017-02-02 07:19:09 GMT-07:00
callhome: key : MessageDescription value : inventory ^\f▒w^O
callhome: message level: 2
callhome: Exiting build_event_notification_payload
callhome: Entering send_snmp_event_notification
callhome: Exiting send_snmp_event_notification
callhome: running cli commands for alert name : inventory, message id : 855636226
callhome: In function schedule_procjob for msg_id: 855636226, alert: inventory
callhome: calling procjob_fork for msg_id: 855636226, alert: inventory
callhome: Callhome handle 23346 added to procjob list
callhome: process scheduled for running cli commands for alert inventory, message id 855636226 ,
callhome: Not Internally generated message
callhome: Added node to the process list with alert name : inventory, message id : 855636226
callhome: No of elements in the process list is 1
callhome: Src: 0x00000101/66 Dst: 0x00000101/54670 ID: 0x08ED5A5E Size: 2740 [RSP] Opc: 2157 (MTS_OPC_CALLHOME_TEST) RR: 0x08ED5A58 HA_SEQNO: 0x00000000 TS: 0xF9B5747C8C568 REJ:0 SYNC:1 OPTIONS:0x0
callhome: Src: 0x00000101/54672 Dst: 0x00000101/66 ID: 0x08ED5A62 Size: 12 [REQ] Opc: 7601 (MTS_OPC_PROCJOB_WAIT_TO_SPAWN_JOB) RR: 0x08ED5A62 HA_SEQNO: 0x00000000 TS: 0xF9B5747DA53C0 REJ:0 SYNC:0 OPTIONS:0x0
callhome: 00 00 5B 32 68 4A 48 1A 00 00 00 01
callhome: Entering run_cli_commands for alert: inventory
callhome: Entering run_cli_commands for alert: inventory, msg_size : 2156, msg_id :49938226,
callhome: CLI_CMD_LIST is !NULL
callhome: executing command:/isan/bin/vsh -c "show vdc membership" -e 0 -q 2 -o 0 | head --bytes=250000
callhome: Using VRF: default
callhome: executing command:/isan/bin/vsh -c "show vdc current-vdc" -e 0 -q 2 -o 0 | head --bytes=250000
callhome: executing command:/isan/bin/vsh -c "show module" -e 0 -q 2 -o 0 | head --bytes=250000
callhome: executing command:/isan/bin/vsh -c "show version" -e 0 -q 2 -o 0 | head --bytes=250000
callhome: Src: 0x00000101/54672 Dst: 0x00000101/66 ID: 0x08ED5BE2 Size: 5244 [REQ] Opc: 7602 (MTS_OPC_PROCJOB_JOB_DONE) RR: 0x08ED5BE2 HA_SEQNO: 0x00000000 TS: 0xF9B57F10419BE REJ:0 SYNC:0 OPTIONS:0x0
callhome: procjobcb_job_done: Handle 23346 syserr "SUCCESS" ret_info_size 5228 ret_syserr 0 ret_info 77f4fe60
callhome: procjob callback called for alert : inventory, message id : 49938226, with procjob handle 23346
callhome: Found procjob handle 23346 with msg_id 855636226
callhome: Callback called for alert : inventory, message id : 49938226 with procjob handle 23346
callhome: Number of entries in cli_cmd_list: 4
callhome: cli command = show vdc membership, cli output file = /dev/shm/callhome.d/workspace//cli_outputVbd9Cu
callhome: cli command = show vdc current-vdc, cli output file = /dev/shm/callhome.d/workspace//cli_outputLNCzkX
callhome: cli command = show module, cli output file = /dev/shm/callhome.d/workspace//cli_output7fFI3F
callhome: cli command = show version, cli output file = /dev/shm/callhome.d/workspace//cli_outputMUIxMH
callhome: Formatting the message for alert : inventory, message id : 855636226
callhome: In function format_and_send_callhome_mesg for alert: inventory, msg_id 855636226
callhome: Procesing for MTS message 1
callhome: In function format_and_send_for_each for msg_id 855636226
callhome: format called for transport method 1, msg_id 855636226, destination_profile full_txt
callhome: executing command:gzip /dev/shm/callhome.d/workspace//workspaceyS0NDc/formatted_message
callhome: Update the zipped file path to /dev/shm/callhome.d/workspace//workspaceyS0NDc/formatted_message.gz
callhome: called for transport method 1 , msg_id 855636226, destination_profile full_txt
callhome: IN transport_callhome_mesg
callhome: Destination profile full_txt
callhome: IN send_callhome_email_mesg with msg_id :855636226
callhome: executing command:mv /dev/shm/callhome.d/workspace//workspaceyS0NDc /callhome/spool//1GyXU8
callhome: Opened:/callhome/spool//1GyXU8/script
callhome: no email address configured for destination profile:full_txt
callhome: problem in creating the email script for destination profile:full_txt
callhome: In cleanup_spool:
callhome: executing command:rm -rf /callhome/spool//1GyXU8
callhome: the process status of my_system is 0
callhome: retcode[0] 23 : retcode[1] 1077608463
callhome: problem in transporting the message Could send message; transport methods failed
callhome: format called for transport method 1, msg_id 855636226, destination_profile short_txt
callhome: executing command:gzip /dev/shm/callhome.d/workspace//workspace8pLiEb/formatted_message
callhome: Update the zipped file path to /dev/shm/callhome.d/workspace//workspace8pLiEb/formatted_message.gz
callhome: called for transport method 1 , msg_id 855636226, destination_profile short_txt
callhome: Destination profile short_txt
callhome: executing command:mv /dev/shm/callhome.d/workspace//workspace8pLiEb /callhome/spool//BqTVOg
callhome: Opened:/callhome/spool//BqTVOg/script
callhome: no email address configured for destination profile:short_txt
callhome: problem in creating the email script for destination profile:short_txt
callhome: executing command:rm -rf /callhome/spool//BqTVOg
callhome: problem in transporting the message Could send message; transport methods failedCould send message; transport methods failed
callhome: format called for transport method 1, msg_id 855636226, destination_profile test
callhome: callhoem alert : inventory
callhome: AML_TAG_CONTACT_EMAIL[[
callhome: ch:SystemInfo[[
callhome: before attachment in aml block
callhome: xml formatter end
callhome: executing command:gzip /dev/shm/callhome.d/workspace//workspacerZS0Si/formatted_message
callhome: Update the zipped file path to /dev/shm/callhome.d/workspace//workspacerZS0Si/formatted_message.gz
callhome: called for transport method 1 , msg_id 855636226, destination_profile test
callhome: Destination profile test
callhome: executing command:mv /dev/shm/callhome.d/workspace//workspacerZS0Si /callhome/spool//3qYKum
callhome: Opened:/callhome/spool//3qYKum/script
callhome: Callhome handle 23394 added to procjob list
callhome: retcode[0] 23 : retcode[1] 0
callhome: EXIT transport_callhome_mesg
callhome: format_and_send successfull for transport method 1 , msg_id 855636226, destination_profile test
callhome: format called for transport method 1, msg_id 855636226, destination_profile CiscoTAC-1
callhome: executing command:gzip /dev/shm/callhome.d/workspace//workspacevrWwCs/formatted_message
callhome: Update the zipped file path to /dev/shm/callhome.d/workspace//workspacevrWwCs/formatted_message.gz
callhome: called for transport method 1 , msg_id 855636226, destination_profile CiscoTAC-1
callhome: Destination profile CiscoTAC-1
callhome: executing command:mv /dev/shm/callhome.d/workspace//workspacevrWwCs /callhome/spool//nVga8A
callhome: Opened:/callhome/spool//nVga8A/script
callhome: no email address configured for destination profile:CiscoTAC-1
callhome: problem in creating the email script for destination profile:CiscoTAC-1
callhome: executing command:rm -rf /callhome/spool//nVga8A
callhome: problem in transporting the message Could send message; transport methods failedCould send message; transport methods failedCould send message; transport methods failed
callhome: At least one message sent successfully
callhome: Exiting send_callhome_mesg
callhome: Successfully formatted and sent the message for alert : inventory, message id : 855636226
callhome: Sending the message for alert : inventory, message id : 855636226
callhome: Src: 0x00000101/54694 Dst: 0x00000101/66 ID: 0x08ED5C07 Size: 12 [REQ] Opc: 7601 (MTS_OPC_PROCJOB_WAIT_TO_SPAWN_JOB) RR: 0x08ED5C07 HA_SEQNO: 0x00000000 TS: 0xF9B5812D72572 REJ:0 SYNC:0 OPTIONS:0x0
callhome: 00 00 5B 62 74 9A BB 43 00 00 00 01
callhome: IN dispatch_callhome_mesg with msg_id 855636226
callhome: executing command:/callhome/spool//3qYKum/script
callhome: smtpclient exit status 1
callhome: <Thu Feb 2 07:19:11 2017> <4> <Thu Feb 2 07:19:11 2017> <4> Command line arguments (0): <Thu Feb 2 07:19:11 2017> <4> Environment variables: <Thu Feb 2 07:19:11 2017> <4> ^I0: SYSMGR_RECOVERY_CFG_DIR= <Thu Feb 2 07:19:11 2017> <4> ^I1: SYSMGR_VDC_SRV_TYPE=52 <Thu Fe
callhome: smtp failure
callhome: email message for profile test
callhome: SMTPclient: In ZULU_CA Code
callhome: SMTPclient: get addr info inputs : mailhost:$smtpServerIp,port:2146966069
callhome: SMTPclient: Host:$smtpServerIp:socket: Invalid argument
callhome: executing command:rm -rf /callhome/spool//3qYKum
callhome: Exiting dispatch_callhome_mesg ret_val :0
callhome: Src: 0x00000101/54694 Dst: 0x00000101/66 ID: 0x08ED5C10 Size: 2136 [REQ] Opc: 7602 (MTS_OPC_PROCJOB_JOB_DONE) RR: 0x08ED5C10 HA_SEQNO: 0x00000000 TS: 0xF9B582C59D08E REJ:0 SYNC:0 OPTIONS:0x0
callhome: procjobcb_job_done: Handle 23394 syserr "SUCCESS" ret_info_size 2120 ret_syserr 0 ret_info 77f4fe60
callhome: procjob callback called for alert : inventory, message id : 49938226, with procjob handle 23394
callhome: Found procjob handle 23394 with msg_id 855636226
callhome: IN CALLHOME_SEND_EMAIL
callhome: problem in transporting the message Error in transporting email message for test SMTPclient: Num of SMTP Servers: 0: Server Name: $smtpServerIp SMTPclient: Port Number : 2146966069 SMTPclient: In ZULU_CA Code SMTPclient: get addr info inputs : mailhost:$smtpServerIp,port:2146
callhome: Entering send_alert_message_send_failure_notification with error code - 1077608457
callhome: mts_send for smtp msg send fail - successfull
callhome: Exiting send_alert_message_send_failure_notification
callhome: Unable to send callhome message for alert : inventory, message id : 855636226
callhome: Could send message; transport methods failedCould send message; transport methods failedCould send message; transport methods failedError in transporting email message for test SMTPclient: Num of SMTP Servers: 0: Server Name: $smtpServerIp SMTPclient: Port Number : 2146966
callhome: setting error code for last callhome message to 1077608465
callhome: No of elements in the process list is 0
callhome: entered into inv_msg_send() function
callhome: in inv_msg_send() current time 7 hours and 19 minutes
callhome: periodic inv counter-- 1495 before increment
callhome: periodic inv counter-- 1496 after increment
callhome: in inv_msg_send() current time 7 hours and 20 minutes
callhome: periodic inv counter-- 1496 before increment
callhome: periodic inv counter-- 1497 after increment
callhome: in inv_msg_send() current time 7 hours and 21 minutes
callhome: periodic inv counter-- 1497 before increment
callhome: periodic inv counter-- 1498 after increment
Thanks!
Everyone's tags (3)
2 REPLIES 2
Highlighted
Beginner
Made some progress. I am able
Made some progress. I am able to get full text emails sent directly to myself. But I haven't configured the mail client on the TG yet, and not sure if it requires XML.
I had to do these two things:
1) Hard-set the "use-vrf" value for the email smtp-server:
transport email smtp-server $smtpServerIp port 25 use-vrf default
Even though the default VRF to use is "default" and the debug output above indicates it was using that.
2) Define an email address for the profile "full_txt" like so:
destination-profile full_txt email-addr person@company.com
Still not able to send XML emails, at least not using any of the "callhome test" commands.
Highlighted
Hi ,
Hi ,
Is the configuration issue resolved ? If the issue is not resolved please raise a TAC case for further troubleshooting and getting the devices registered for SCH.
Please let me know if you need any assistance in raising the TAC case ?
Pramod
Content for Community-Ad
Cisco Community May 2020 Spotlight Award Winners
