04-14-2017 06:04 AM
I can not SSH to CSPC 2.7 after a new install and password change.
Do I need to reinstall the server to get it working again?
Solved! Go to Solution.
04-27-2017 05:44 AM
Try to use the following user and password after a 30 minute period.
admin
Adm!23min
If you haven't changed the password it should work.
04-14-2017 06:09 AM
With the new CSPC 2.7 image, if up to 3 failed login attempts have occurred back to back, it will temporarily lock the account for 30 minutes. Can you please try and see if you're able to login after a 30 minute period?
Thank you,
Jarrett
04-14-2017 07:09 AM
Same result after 1 hour wait time. Attaching screenshot. Admin usr works as expected on the web browser.
04-26-2017 12:31 PM
04-26-2017 01:22 PM
No answer or solution provided yet. Still can not login through SSH.
04-26-2017 01:28 PM
Hello, can you please post a screenshot of any error messages you receive?
In addition, what ssh client are you using?
Does the behavior repeat for all users? - admin/collectorlogin ??
Cesar
04-27-2017 12:12 AM
04-27-2017 05:44 AM
admin
Adm!23min
05-03-2017 07:06 AM
I have reinstalled the ova and I can now login using admin and collector login accounts but I have a problem with root user is locked for more than 24 hrs.
I need to unlock it to be able to extract the collector file manually to upload it to Cisco portal.
04-25-2017 10:59 AM
04-12-2018 12:55 PM
I have a similar issue, I waited for more than 30 minutes and I'm still locked...
When you say "if you haven't changed the password", are you talking about the WEB interface admin account or the ssh account?
Does the web interface and the shell share the same accounts?
04-12-2018 02:53 PM
Hi Steve,
For tracking and to allow visibility to your request we ask that you start a new discussion. Our experts can help from there.
Cheri
