Hi,I get an error (in the attached image) when trying to access the SNTC portal.Is there a known downtime? If so when will the portal be available? Thank you,Alex
Hello, I am having issues registering a new collector to the SNTC portal. I get this error message. "Entitlement file generation failed. Please try again. If the issue persists, find help in the community." My CSP-C version is 2.7.4 Thanks!
I am unable to generate a CSP-C entitlement, receiving the "Entitlement file generation failed." error. I've tried solutions offered in other discussion threads, including alternate browsers, restarts, and cache clearing, but to no avail. Could someo...
I have a customer that the SNTC portal is showing devices as uncovered when they do indeed have active SMARTnet support. I have confirmed in CCW-R that all of the S/N for ASA firewalls and ASR routers have active SNTP SMARTnet. I am working with my c...
Hi,I am having issues that CSPC (Version 2.8.1.4) is not showing product family and Serial number of discovered devices even though the option is selected Yes --Serial Number Duplicate check under Settings-Discovery Settings. I have used SNMP and SS...
Customer is wanting info on Con-SNT-SMS-1000 and Con-ECDN-SMS-1, they are mainly concerned that onsite is mentioned. This is just for software and hardware replacement of devices with no onsite is that correct
Hello, I am running into an issue and was hoping that the community may be able to provide some guidance. I have recently been tasked with overseeing our SNTC Portal and CSPC, and have ran into a few hurdles. My first issue is that there are devices...
SNTC Portal - Schedule Report under Actions, frozen/spinning/doesn't load I've attempted to access the "Schedule Report" section of the SNTC portal for a few days now, and between my boss, a coworker, and myself - and between IE and Chrome - we are u...
i am unable to login to SNTC portal, it always redirects to below portal. I have completed the registration but still cannot login. https://www.cisco.com/web/fw/tools/ssue/apps/ssueap2.0/prod/#/promo username : abythomas3 *********...
Hi everybody. I have the next situation: I installed the CSPC Collector 2.8 appliance in my customer platform. We generated the certificate using a valid Cisco contract and the appliance was registered without any issue. The devices were discovered a...
Hello, The information on the SNTC Portal is updating well, however, there´re a signiicant amount of duplicate equipments. Anyone know how may I eliminate these data? Is there any automaticaly or manual mode to do this? Regards,
In an attempt to fix the upload error bug, a customer attempted to login to CLI. They had to reset their CLI admin password and now as soon as they login, the screen flashes quickly to appear the login completed, but then goes right back to login pr...
Had to deploy a new collector for customer and discovery and collection work, but it fails on the upload. Giving generic error of Upload Failed, internal server error. Collector can reach internet and not using proxy. Firewall possibly blocking ou...
Have a customer who has just completed the registration for SNTC and would like to set up collector ASAP. Is there any way the registration can be hurried along today?
I have a customer that is wondering if there is a way in the SNTC portal to show if a device is deployed as a redundant pair or high availability. If the devices has HA or redundancy, they want to cover with 8x5xNBD; if the device has a single home w...
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
| Asunto | Autor | Publicado |
| 03-19-2025 06:01 AM | ||
| 03-17-2025 01:43 PM | ||
| 03-16-2025 07:08 PM | ||
| 03-04-2025 07:40 PM | ||
| 02-25-2025 05:24 AM |
