04-16-2019 11:05 PM
I have registered a wrong CCOID as Delegated Administrator for my company in Smart Net Total Care portal. Since it was a mistake, I would like to remove it and register the proper one. Despite reviewing different posts about this topic, I cannot see how to do it by myself, so I think I need help to deal with this.
Solved! Go to Solution.
04-16-2019 11:14 PM
Hi @fdanielgarcia ,
You must write a direct message to @Suchita Shewale with your requirements and credentials so that he can help you.
04-16-2019 11:14 PM
Hi @fdanielgarcia ,
04-22-2019 11:56 PM
04-23-2019 05:05 AM
Hi @fdanielgarcia ,
I'm glad your problem has been fixed.
Remember to mark the correct answers as solved, since that helps other users with similar
