CSAM Access
We have been registered as DA for our organization and still unable to access CSAM , required access at the earliest as we need to implement CSPC
Thanks & Rgds,
Kiran
2 Accepted Solutions
Hey NetworksNetworks9752,
It appears you are not looking in the right portal, you are in SmartAdvisor.  It appears you are looking for SNTC so that you can associate your CSPC collector and upload.  CSAM is the initial registration that must be done in the onboarding process.  You are now DA and get add users/access.  See below, the first link is in regards to Roles and Access.  You must provide your CCO ID with the desired role.  Once it has been added, let me know so I can push a sync.  I have also included the SNTC User guide, second link below.
https://www.cisco.com/c/en/us/support/docs/services/sntc/portal_administration.html#roles-access
https://www.cisco.com/c/en/us/support/docs/services/sntc/portal_user_guide.html
Justin
Hi Jumin ,
Thanks a lot , i have added Role to the CCOID  can you do a sync
Thanks & Regards ,
Kiran
6 Replies 6
jumin
Please private message me the CCO ID.
Justin
Hi Jumin ,
Replied with the details , Kindly check your inbox and do the needfull
Thanks & Regards ,
Kiran
I have checked the details and synced the account.  You should be able to access CSAM as DA now.  Try to access via link below and let me know if you are successful.
https://cdceb.cloudapps.cisco.com/csam/
Justin
Hi Jumin ,
My only intention is to implement CSPC collector for which i have registered as DA and now with your help got CSAM access
As per the CSPC collector installation guide , for registering CSPC collector i need to login to services.cisco.com
After logging i couldn't able to see the CSPC Registration option
Kindly let me know how to get this address , attaching the image for your reference
Justin
Hi Jumin ,
Thanks & Regards ,
Kiran
