CSP CLI closes after login
David Draper
Tried to update to CSP 2.7 and when I logged in I was required to change my password.  Now when I log back into the CLI I see this message:
java.net.ConnectException: Connection refused (Connection refused)
 at java.net.PlainSocketImpl.socketConnect(Native Method)
 at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
 at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
 at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
 at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
 at java.net.Socket.connect(Socket.java:589)
 at java.net.Socket.connect(Socket.java:538)
 at java.net.Socket.<init>(Socket.java:434)
 at java.net.Socket.<init>(Socket.java:244)
 at com.cisco.ca.ss.lcm.adminshell.client.ShellClient.main(ShellClient.java:51)
Error occured: could not connect to the database server.
Please make sure mysql database server is up and running.
taywelch
Hello David,
It looks like the admin shell never came back up after the upgrade. Can you reboot the collector and see if admin shell restores?
Taylor
5 Replies 5
I have the same issue, I literally just upgraded (or attempted to) to 2.7. I used the CLI to do the install and it never gives any output on the status of it. I come back and attempt to log back in and it will quickly show those Java errors.
Funny you posted this only a few hours ago haha.
antchris
Hello David,
This generally happens when attempting to login to as the CSPC is still spinning up - although you may be able to ping and have ssh connection, the admin shell is one of the last services to start.
Best practice is to allow a few moments post restart/reboot before logging into the admin shell - you should not receive the java/db connection error.
taywelch
Hello David,
Taylor
David Draper
I ended up just rebuilding the collector on 2.7.  I tried rebooting the collector multiple times without success.  Thanks for help!
-Dave
Dave,
I did the same thing as well, just rebuilt it. I think that something happened going directly from 2.6 to 2.7 and corrupted the build. It works fine now, I just wish I could narrow it down to what exactly caused that hassle.
Thanks!
