CSPC 2.10 deployment failed
alan.pimentel
Hi there,
I'm trying to deploy CSPC OVA. version 2.10.0.1 and I'm facing the error message down below:
My ESXi version is 5.1.0. Could it be my ESXi verison the problem?
Best Regards
dbourai
Hello Alan,
For the deployment for the CSPC 2.10.0.1 OVA version, you will need ESXi 6.5 or higher. Only the supported Esxi version should be used for the deployment of the latest CSPC OVA.
Attaching the CSPC User-Guide as well.
Thanks & regards,
Devashish Bourai.
dbourai
Hello Alan,
This post has been acknowledged by us. We will get back to you with an update regarding this.
Thanks & regards,
Devashish Bourai.
dbourai
Hello Alan,
Thanks & regards,
Devashish Bourai.
