05-01-2018 06:29 AM - edited 03-12-2019 07:47 AM
Fellow Networkers,
Having CLI applied CSPC v2.74:
admin# show apply
Version Number : sp-30.0.4-0-0-lnx64
Status : Applied
Start Time : May/01/2018 12:26:15
End Time : May/01/2018 12:37:32
admin# sho version
Build-name : Collection Platform Software 2.7.4
Version : sp-30.0.4-0-0-lnx64
I get the following popup: Error: Unable to get data from server for report:register when trying to Connect to the collection server.
A similar popup appears when I select Get collection platform software updates. This time the popup states: Error: Unable to get data from server for report: available_updates.
Setting to the reoccurring schedule is also out of the question.
Interestingly, I can reinitialise my CCO credentials from the CLI:
admin# conf server disable
This operation will disable connection with server for Software Updates.
Would you like to continue (y|n)? y
Operation succeeded.
admin# conf server enable
This operation will enable connection with server for Software Updates.
CCO Id : Frustrated.Engineer
Password :
Advice and Guidance would be gratefully received.
Thank you in anticipation.
Solved! Go to Solution.
05-01-2018 06:32 AM
05-01-2018 06:32 AM
05-01-2018 06:49 AM
Hi Justin,
School boy omission; should have tried an alternative browser first. Chrome is good.
Thank you very much.
Michael
