el 10-25-2022 04:03 PM
Looking to configure MFA or block access via source IP to the administration web page of the CSPC. Anyone know if CSPC has an ACL/NAC feature to block by source IP? it is possible to run fallwalld in the Guest OS to achieve desired request?
Thanks in advance!
David Undernehr
el 10-26-2022 06:07 AM
Hi David,
This is to acknowledge you that your post is accepted by me and will assist you shortly
Thanks and Regards,
Madhusha R
el 10-27-2022 03:38 AM
Sounds good Madhusha, looking forward to your assistance.
David Undernehr
el 10-27-2022 05:44 AM
Hi David,
Currently, MFA feature is not available to block access to the Web page of CSPC GUI. However, you can set up an SSL certificate for the collector.
Kindly let us know your inputs so that we can assist you accordingly.
Thanks and Regards,
Madhusha R
el 11-01-2022 08:44 AM
Thank you Madhusha for the assistance. You have been most helpful in ruling out our options. Unfortunately, SSL doesn't meet our needs for this particular issue but will keep it in mind.
Thanks again!
David Undernehr
el 11-01-2022 08:49 AM
Hi David,
Thanks for the update.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
