CSPC Certificate replacement
dfinibg6
Hi Community,
I am trying to replace the existing SE certificate with a SNTC certificate in my Collector. I could not use the "Replace" option, so I added the SNTC Certificate and then Deleted the SE Certificated.
The only certificate now is the SNTC certificate, however in Server Properties it is still showing the SE Certificate as Appliance ID. Obviously, this is generating an error when trying to upload data into SNTC (Internal Server Error)
Any ideas?
dfinibg6
I fixed the issue by changing the "Connectivity Certificate" and "CSPC Identity" values in "Application Settings", for the new SNTC certificate.
adias
Can you please send me the screenshot of where you are seeing : (Server Properties it is still showing the SE Certificate as Appliance ID)
dfinibg6
