CSPC Configuration
brcollector
It's possible to change the CSPC VM size (disk size, RAM memory, vcore) when the VM it's already created? From Large to Medium, Medium to Small, etc?
If it is possible, is possible with both, OVA and ISO?
aloksin3
No It's not possible to change the CSPC VM size (disk size, RAM memory, vcore) when the VM it's already created?
You need to redeploy the VM to make any changes.
Thanks & regards,
Alok Singh
jrubioga
It's possible, and the steps may vary depending on the virtual environment you're using, you can power off your machine and assign the resources you require on the server settings:
• Small Deployment
    • vCore count: 4
    • RAM: 4 GB
    • HDD: 250 GB
• Medium Deployment
    • vCore count: 8
    • RAM: 8 GB
    • HDD: 500 GB
• Large Deployment
    • vCore count: 12
    • RAM: 16 GB
    • HDD: 1 TB
Let us know if this worked for you,
Julian Rubio
Hi Julian,
Is this possible with both type OVA and ISO?
