CSPC on Hyper-V
barasniewski
I need to install a CSPC server in HyperV plataform. From what I checked in the documentation, this is possible, but I did not find any documents with the steps that I must follow with HyperV, I found only with VMWare. Is there a document that can help me step by step?
Leandro Barasniewski
Jarrett Pomeroy
Hello barasniewski,
Unfortunately, Hyper-V is not a currently supported platform for CSPC.  We do offer a ISO image of the CSPC which may work for your use case, you can find ISO installation steps available here.
Thank you,
Jarrett
Jarrett Pomeroy
Hello barasniewski,
Thank you,
Jarrett
It seems that VMWare ESXi 6.0 kan be installed in a Hyper-V VM
https://www.vembu.com/blog/installing-esxi-6-0-in-a-hyper-v-virtual-machine/
I'm wondering if Cisco supports a CSPC installation in a nested ESXi inside a Hyper-V VM?
Hi Daniel,
Cisco has not certified CSPC to run on Hyper-V, therefore is not supported.
Cheers,
Cheri
