05-08-2015 07:56 AM
How can I get CSPC Reports from older Inventory Uploads?
Currant upload Data is from: 5. May 2015 Previous upload Datas are from: 28. April 2015 / 9. April 2015 / 13. March 2015 / December 2015
I would like to get a CustomerInventory Report from an older upload (28.4.2015).
How can I get them (or other older reports as well)?
Thanks for your help.
Urs
Solved! Go to Solution.
05-20-2015 11:30 PM
Hello Randy,
Aggregated report will give you aggregation of all the devices from different inventory uploads done in recent and past for that account (whenever you generate the report ).
If there's a device which was uploaded as part of 1st upload and if same device is uploaded as part of 2nd upload, then the date will show as 2nd uploaded date.
Thanks & Regards,
Jaswant Gills
05-12-2015 05:01 PM
Hello Ursmeier,
Thank you for reaching out to SNTC team for help.
Unfortunately, current functionality of SNTC does not allow to generate CustomerInventory Report from an older upload once latest upload is completed successfully. CustomerInventory Report is generated on latest uploaded data.
If you are interested to know what devices are Added or Deleted in compare to an older upload with that of latest upload, then you can find these by generating Inventory Delta Report.
Path for generating Inventory Delta Report :
Under Reports Page --> Delta Reports --> Inventory Delta Report , you can select Network Snapshot One and Network Snapshot Two by selecting different uploaded dates.
Thanks & Regards,
Jaswant
05-12-2015 05:25 PM
Jaswant - I must be confused. I was under the impression that the aggregated report would give you ALL uploaded data. Please let me know if I am wrong.
05-20-2015 11:30 PM
Hello Randy,
Thanks & Regards,
Jaswant Gills
