03-25-2019 08:17 AM
When trying to upgrade, because of CVE-2019-1723, gone a week and download stuck:
admin# show download
Version : sp-30.1.1-2-0-lnx64
Download Location : -
Status : Downloading
Start Time : Mar/18/2019 10:50:02
End Time : -
Reason For Failure : -
admin# show version -d
Build-name : Collection Platform Software 2.8.0.1
Package-type : ServicePack
Version : sp-30.1.0-1-0-lnx64
Component : CSPC Base
Version : 2.8.0.1
Package-type : JeOS
Version : jeos-30.1.0-1-lnx64
Component : AdminShell
Version : 1.8.1
Component : LCM
Version : 1.8.1
Component : CASP
Version : 2.8.0.1
Component : ConcsoTgw
Version : 1.7.3
Component : Hardened CentOS
Version : 6.10 patch#0
admin# check update
Patch versions
Version Number: sp-30.1.1-2-0-lnx64
Description: Collector patch to upgrade to CSPC 2.8.1.2
Required Versions: -
Optimal JeOS: jeos-30.1.1-2-lnx64
Reboot Needed: Yes
Restart Needed: Yes
Package Size: 1111718852 bytes
Contents:
Component Name: Rules Pack
Version: 4.9
Description: 4.9
Component Name: CSPC Base
Version: 2.8.1.2
Description: CSPC Base 2.8.1.2
Installable: Yes
[root@ats-pss ~]# ls -lart /opt/LCM/tmp/
total 5478056
-rw-r--r--. 1 casuser casusers 919595013 Oct 24 2017 sp-30.0.2-0-0-lnx64-package.zip
-rw-r--r--. 1 casuser casusers 1110821911 Apr 11 2018 sp-30.0.4-0-0-lnx64-package.zip
-rw-r--r--. 1 casuser casusers 1628123223 Oct 20 12:20 sp-30.1.0-0-0-lnx64-package.zip
-rw-r--r--. 1 casuser casusers 1950954244 Dec 6 11:09 sp-30.1.0-1-0-lnx64-package.zip
drwxr-xr-x. 10 casuser casusers 4096 Dec 6 11:19 ..
drwxr-xr-x. 2 casuser casusers 4096 Mar 18 10:50 .
[root@ats-pss ~]# ls -lart /opt/LCM/tmp/downloads
ls: cannot access /opt/LCM/tmp/downloads: No such file or directory
[root@ats-pss ~]#
[root@ats-pss ~]# tail /opt/LCM/logs/install
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
107 858 107 858 0 0 1078 0 --:--:-- --:--:-- --:--:-- 5296
107 858 107 858 0 0 783 0 0:00:01 0:00:01 --:--:-- 5329
RetVal:0
RetVal:0
ASD-DOWNLOAD: Checksum error. Downloaded file is corrupted. (48ead4c4292151d72e6ded3df273cdf1, cc189b6f70f2e1d374e43de42b52b300)
ASD-DOWNLOAD: Checksum error. Downloaded file is corrupted. (b87c1ba98d7cb9a4ffb86d7be0d31dc0, a6f689f78add5b8138455a2dc3a9f1d4)
Am I hitting the "Software Updates Page Spins Only Loading Message" problem? and should I proceed with:
To resolve the spinning message issue, perform the following :
1. Login to collector appliance as collectorlogin.
2. Switch to root using su – command.
3. Get the casuserDownload_Failed.zip from here.
4. Unzip casuserDownload_Failed.zip and run cd to casuserDownload_Failed folder.
5. Run install.sh as root.
6. Login to CSPC UI and go to Software Updates and re-trigger upgrade.
03-25-2019 04:55 PM
03-26-2019 08:01 AM
03-26-2019 08:53 AM
