04-30-2018 03:33 PM - edited 03-12-2019 07:47 AM
I made some changes to the credentials I'm using to access the devices I'm managing. To ensure they are working I ran "Verify Device Access". It seems to have run fine. But when I want to look at the results, the Verification Time and the Source reference a Device Access Verification job I ran last Friday, not the one I just ran.
I'm running collector version 2.7.4. I went into the Advanced Options for the DAV job and selected all 5 of my access methods (Telnet, SSH1, SSH2, SNMPv1 and SNMPv2c) to make sure that they were actually being used, but no joy.
Solved! Go to Solution.
05-02-2018 07:17 AM
04-30-2018 05:11 PM
Can you please also include screenshots of the DAV Job Report and windows which are showing the DAV results in this post or a private message? From there, I will take a look and see what may be happening.
Thank you,
Jarrett
05-01-2018 07:04 AM
Here's the screen shots.
05-01-2018 10:24 AM
05-02-2018 07:17 AM
05-02-2018 08:30 AM
It's not clear to me what you mean by this. Do you mean that in the second screen shot above all protocols must be moved to the right AND credentials provided for all of them? We don't even permit all of those to be used to access our devices.
05-02-2018 08:52 AM
05-02-2018 12:10 PM
O.K. that worked. But why does it work that way? What's the point of being able to tell the system not to test certain access protocols if you end up with bad data in the output?
05-02-2018 01:14 PM
05-02-2018 02:30 PM
O.K. Thanks!
