el 08-05-2020 08:21 AM
¡Resuelto! Ir a solución.
el 08-08-2020 01:26 PM
I see you removed yourself as the Delegated Administrator (DA) for CINTAC today, can you explain why this was done? Without this role you cannot assign yourself or others roles within SNTC. Please review this guide on how to assign yourself the role of Customer Admin for SNTC, https://www.cisco.com/c/dam/en/us/applications/spptauth/sam-help-guide.pdf#viewuserparty, and I will proceed with making you the DA again.
el 08-10-2020 08:39 AM
Hi Ana,
I've removed the previous association to the original entitled company and confirmed that the records updated after the latest sync; you should now see the correct EC name within the SNTC portal.
For future reference, it is important to note which entitled company details are presented during the self-onboarding process. If there is a concern or mismatch in expectations then this forum can be a valuable resource. Otherwise, direct support is available via the following email group:
sntc-support@cisco.com
el 08-05-2020 12:15 PM
el 08-06-2020 04:15 PM
Thanks Justin I will validate and I will tell you how it goes
el 08-07-2020 06:27 AM
Justin, I have completed CSAM but still cannot generate a new CSP-C entitlement
el 08-07-2020 06:53 AM
I have realized that the company with which the SNTC portal was associated is Novacero SA and it should be Cintac SA, could that be causing the problem?
el 08-07-2020 07:25 AM
What I indicated, my company is CINTAC SA and the SNTC portal mistakenly put NOVACERO SA. can we modify that?
el 08-07-2020 12:32 PM
el 08-07-2020 02:13 PM
I have returned to https://cdceb.cloudapps.cisco.com/csam and verify that everything is correct. But NOVACERO SA still appears in the SNTC portal and it does not allow me to generate the CSP-C.
el 08-07-2020 03:01 PM
First you must go to CSAM and provide yourself only the Customer Admin role for SNTC with CINTAC.
Then while in SNTC you need to select this company CINTAC and generate the certificate there.
el 08-08-2020 11:17 AM
I have done what you tell me but NOVACERO continues to appear on the SNTC portal.
remove the company from the following link as recommended by support (https://rpfa.cloudapps.cisco.com/rpfa/profile/requestorupdate_association.do), but I still can't solve the problem
Hi Ana,
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
