02-07-2019 04:48 AM
I did an upload of data from Solarwinds and although Solarwinds has all correct hostnames, many of the hostnames in the portal are showing as something not recognisable like 198:SW167727
02-18-2019 07:39 AM
Hi Tania,
Apologies for the delay.
I reviewed the devices that have hostname reported as SW###. It appears that these devices that are either collected more than once or have no host name collected at all. You may want to review the Solarwinds collection file to see if there are any issues during collection.
02-18-2019 10:28 AM
10-02-2019 01:30 PM
i have this problem as well - hostnames are showing up as SW xxxx in the Smart Net Portal after import. However in Solarwinds, its correct. How do you fix this?
10-02-2019 02:28 PM
02-06-2020 12:59 PM
Hello
I just went through the process of downloading the SolarWinds NCM connector for Smarnet Advisor and I am still experiencing the same issues with hostnames showing up as 198:SWXXXXX. The funny thing is not all my 305 devices are in that format. Some did come across with the proper hostname reflected in SolarWinds.
Has anyone discovered a solution?
