Inventory report does not show 6800 supervisor cards
jpreston4
The report shows chassis and other modules but not the 6800 sup cards. The report also shows 6500, 4500, Nexus sup cards. Antone had any luck with 6800 sup cards ?
Thanks for the info via PM.  You have a C6880-X-LE.  The Supervisor is not a field-replaceable unit (FRU) on that chassis so that is why we don't display it in your inventory.  You would not have any contracts for it or ever any alerts on it.  The Sup6T is supported on the 6807-XL as a FRU.  See:  http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-6800-series-supervisor-engine-6t/datasheet-c78-736408.html.
Hope that helps.  Looks like you're not missing anything.
Chris Camplejohn
Which supervisor module are you expecting to see?  If you send me a private message with your company name, inventory name and specific device we can look at it further.  Follow these steps to send a private message in the forum.
thanks
