cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Modules incorrect in inventory
dan.reid
We have several 3850 stacks for access. In the inventory the uplink module is reporting as C3KX-NM-10G which is EOL but the modules are actually C3850-NM-2-10G as reported by a show inventory on the switch stack.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Nevermind Dan.  I found the info I needed and I understand why the wrong PID is being shown to you.  The SNMP OID for this card was already in use from another Cisco Product.  We have captured that change already but it has not made it into the production portal, so I'm checking on the timeline for that.
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
Chris Camplejohn
Can you provide "show inventory oid" output?
Thanks!
Chris
NAME: "c3xxx Stack", DESCR: "c3xxx Stack"
PID: WS-C3850-48P , VID: M0 , SN: FOC1802U0K6
OID: 1.3.6.1.4.1.9.12.3.1.11.18
NAME: "Switch 1", DESCR: "WS-C3850-48P"
OID: 1.3.6.1.4.1.9.12.3.1.3.1212
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-1100WAC , VID: V01 , SN: LIT1745174V
OID: 1.3.6.1.4.1.9.12.3.1.6.395
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC18025PL2
OID: 1.3.6.1.4.1.9.12.3.1.9.2.280
NAME: "GigabitEthernet1/1/1", DESCR: "1000BaseSX SFP"
PID: , VID: , SN: FNS0940B04V
OID: 1.3.6.1.4.1.9.12.3.1.9.51.138
NAME: "Switch 2", DESCR: "WS-C3850-48P"
PID: WS-C3850-48P , VID: M0 , SN: FOC1802X0M0
NAME: "Switch 2 - Power Supply A", DESCR: "Switch 2 - Power Supply A"
PID: PWR-C1-1100WAC , VID: V01 , SN: LIT17370XVS
NAME: "Switch 2 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC180329RG
NAME: "GigabitEthernet2/1/1", DESCR: "1000BaseSX SFP"
PID: , VID: , SN: AGM112614MB
NAME: "Switch 3", DESCR: "WS-C3850-48P"
PID: WS-C3850-48P , VID: M0 , SN: FOC1802Y2J3
NAME: "Switch 3 - Power Supply A", DESCR: "Switch 3 - Power Supply A"
PID: PWR-C1-1100WAC , VID: V01 , SN: LIT17370XH1
Thanks.  This helps.  We're analyzing this and will get back.  Would you by chance be able to provide an SNMP walk of the EntityPhysical table for one of these devices?
