No Inventory Available for Import
Jason Granat
Level 5
Level 5
We have the collector registered and we are attempting to perform a device import. We have downloaded the template CSV file but there does not appear to be any option to actually upload it. The portal says to select an inventory, but no inventories exist and we do not see a way to create an inventory.
Thank you
Jason
Hi All,
This issue is fixed , could you please try it now.let us know if you still face any issue.
Thanks & Regards,
Anusha.
6 Replies 6
Scullen_Daniel
Identical problem here. I have opened a case with support and will post if I get a fix.
Dan
Hello  ,
We are aware of this situation and we are working with engineering team already on priority for this issue , We will keep you posted with an update once the issue gets handle from our side .
Pamela
Excellent, thank you!
Hi All,
Thanks & Regards,
Anusha.
Looks like all is good at this point, thanks!
npicard
Thank you for your inquiry. I have requested our back-end team investigate and will provide an update as soon as possible.
