06-09-2020 08:15 AM
Hi there
I have a couple of Nexus 3172 switches and my Smartnet contract is due for renewal. When trying to renew via a reseller, I found out that the previous reseller registered the contracts with them being the end user and not my organisation.
I have proof of purchase (their invoice to me) showing I own the switches and bought and paid for the support contract - how do I go about getting the end user details changed to my organisation so I can renew the contracts?
Thank you!
Solved! Go to Solution.
06-09-2020 01:02 PM
Hello shoaiblaher,
Unfortunately, TAC is unable to assist directly with contract coverage orders as we are dedicated to the resolution of technical HW/SW issues so I will need to refer you to another resource that is better aligned to answer your query regarding coverage compatibility:
Using the below Cisco Commerce resource, you may navigate to the below URL and open a ticket (The floating ‘Help’ menu will allow you to open a case with the Commerce Support resources): https://apps.cisco.com/Commerce/home
You can also send an email to services-entitlement-help@cisco.com. A entitlement support Specialist will be able to provide you information or instructions about your contracts.
Thank-you
06-09-2020 01:02 PM
Hello shoaiblaher,
Thank-you
