10-06-2017 06:00 AM - edited 03-12-2019 07:30 AM
When I try run an Discovery they return the error : SNMP Unreachable or Incorrect.
I already check if all switch has the community configured and if this community are correctly typed on collector credential.
And When I run the Discovery
If anyone help me.
Tks so much
Solved! Go to Solution.
10-06-2017 06:03 AM
Can you check from the command-line of the CSPC to validate one of those hosts is really ICMP reachable (ping) and you can manually snmpwalk from the CLI of the CSPC? It could be a route issue or an ACL issue on the devices or a firewall issue blocking access.
10-06-2017 06:03 AM
10-06-2017 06:10 AM
10-11-2017 02:00 PM
Please let us know if you need further assistance. If not, please mark this as solved to close the conversation.
Thanks!
Cheri
