SNMP Credentials Unreacchable or Incorrect SNMP Community
When I try run an Discovery they return the error : SNMP Unreachable or Incorrect.
I already check if all switch has the community configured and if this community are correctly typed on collector credential.
And When I run the Discovery
If anyone help me.
Tks so much
Chris Camplejohn
Can you check from the command-line of the CSPC to validate one of those hosts is really ICMP reachable (ping) and you can manually snmpwalk from the CLI of the CSPC?  It could be a route issue or an ACL issue on the devices or a firewall issue blocking access.
Chris Camplejohn
Tks Chris. I'll check this points.
Please let us know if you need further assistance. If not, please mark this as solved to close the conversation.
Thanks!
Cheri
Recognize Your Peers
