SNTC 3x Not Available
Kyleigh Wells
Beginner
Beginner
Receiving the following on logging into SNTC for past 2 days:
Smart Net Total Care 3x portal is currently unavailable. We are actively working to resolve the issue.
We should be back online shortly. Meanwhile, please refer to the community for questions and updates.
Please advise issue or ETA.
Kyleigh Wells
tnewell
Hello -   The SNTC 3.0 portal was decommissioned quite a while ago. What url are you using to access the portal?
adias
The correct URL is https://services.cisco.com
The 3x portal itself would still be visible but not accessible to outside users. and it is used for developers in testing. I believe you either was not on boarded correctly or is having connectivity issues to the correct Service is are supposed to be associated with.  Please send me in private your cco user id  and the company name you believe you are associated in SNTC.services.JPG
adias
Going to the correct URL worked for you?  If so please mark this post as resolved, to limit my response communications.  If not please let me know if you still have the problem
Recognize Your Peers
