11-22-2019 06:45 AM
Receiving the following on logging into SNTC for past 2 days:
We should be back online shortly. Meanwhile, please refer to the community for questions and updates.
Please advise issue or ETA.
Kyleigh Wells
11-22-2019 11:36 AM
Hello - The SNTC 3.0 portal was decommissioned quite a while ago. What url are you using to access the portal?
11-22-2019 02:02 PM - edited 11-22-2019 02:05 PM
The correct URL is https://services.cisco.com
The 3x portal itself would still be visible but not accessible to outside users. and it is used for developers in testing. I believe you either was not on boarded correctly or is having connectivity issues to the correct Service is are supposed to be associated with. Please send me in private your cco user id and the company name you believe you are associated in SNTC.
12-06-2019 07:04 AM - edited 12-06-2019 07:04 AM
Going to the correct URL worked for you? If so please mark this post as resolved, to limit my response communications. If not please let me know if you still have the problem
