07-30-2020 05:14 AM
Can't access the portal, it says.
You do not currently have access to Smart Services Connection. You must be entitled to at least one Smart Services contract to request access.
However i do have access, when a try to register again it confirms it and send me back, getting into a loop.
I can't understand why it is so hard to work.
Can someone please help me?
Thanks in advance.
Solved! Go to Solution.
07-30-2020 06:34 AM
If you had recently requested access to the SNTC portal you may not have waited to requisite 24 hours for the systems to sync up. Either way, I have done this manually and you should now have access to the portal, please confirm any remaining access issues here.
Thank you
07-30-2020 06:34 AM
Thank you
07-30-2020 06:38 AM
hello jofrumki,
I waited close to 48 hours to report here.
I got access now.
Thank you a lot!
Kind regards
João Belo
