03-13-2018 09:38 AM - edited 03-12-2019 07:42 AM
I have deployed Common Services Platform Collector and successfully retrieved my devices information, created upload profile and uploaded the inventory 3 times via the collector. Portal shows three uploads succeeding, but I still show no devices in the inventory. Any ideas?
Solved! Go to Solution.
03-13-2018 11:52 AM
In this version of CSPC, there is no need to have a separate upload profile.
Please try the following:
03-13-2018 09:42 AM
03-13-2018 10:01 AM
CSP0009033779
03-13-2018 10:05 AM
03-13-2018 10:08 AM
03-13-2018 11:40 AM
Thanks for your response. This is a new deployment, so everything is default. After I deployed this I ran the discovery and made sure to create the upload profile and run the upload. I am attaching the screenshots for both profiles.
03-13-2018 11:40 AM
03-13-2018 11:52 AM
03-13-2018 12:48 PM - edited 03-13-2018 12:49 PM
So I re-ran the process as you recommended and ended up with the same result. I started looking at the portal and it seems that under Inventory Insight it shows that exactly 332 devices are placed in the "Not Collected" category with the reason code of "Not Reachable". It was reachable on CSPC, but not on the portal.
03-13-2018 12:56 PM
03-13-2018 12:59 PM
03-14-2018 01:48 PM
