07-13-2018 12:07 PM 03-12-2019 07:53 AM 更新
I'm a SNTC "CustomerAdmin" role.
I setup multiple segments with various criteria.
The segments work fine as assigned to our users with "CustomerUser" role.
The "CustomerAdmin" users are not listed to be assigned to segments.
I would like to utilize the segments to filter/sort when looking at inventory.
However the segment field shows blank on all inventory items.
Is there a way to see/utilize the segment field as a "CustomerAdmin" user?
I would prefer not create extra "CustomerUser" account(s) to see each segment's inventory.
解決済! 解決策の投稿を見る。
07-13-2018 12:27 PM
If you would like to utilize filter, please use segment or all segments from global filter instead of inventory.
Supriya
07-13-2018 12:13 PM
07-13-2018 12:20 PM
The devices & sub-components are listed in inventory...however the segment field is blank and not able to be used to filter or sort.
07-13-2018 12:27 PM
Supriya
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
