Trial for 2.10.0.1-B-7
vivarock12
is it posible to use the trial version of the CSPC, because im getting this error
"Applying trial license on CSPC timed out. Please try Again"
i have seen some post that saids that is not available at the moment, can someone confirms this?
thanks,
for the help
shipand2
Hey,
I hope you are doing well!
let me check I will get back to you with an update.
Shivam Pandey
Thanks for the help
We would like to inform you that for all the collectors (Trial certificate, upgrade, cco setup) the Trial version isn't supported due to which you are receiving the "Timed Out" error. The CSPC collector requires the services of either SNTC or BCS.
If you are looking to avail the SNTC services, then in this case you need to create an SNTC account and generate the Entitlement for the same.
Shivam pandey
