05-25-2017 04:21 PM - last edited on 10-18-2017 01:36 PM by Cheri Fairbrother
The CSPC is not able to send the profile results to the Cisco backend due to the following error. I doubt it is blocked by our proxy server or firewall. I wonder what IP address(es) and port(s) I need to permit?
[ERROR] [2017-05-25 18:41:46,205] : [Thread=SimpleThreadPoolWorker-4][Class=com.pari.nm.modules.upload.UploadHandler][Method=sendFile][line=87][Inside UploadHandler sendFile.
[ERROR] [2017-05-25 18:41:46,205] : [Thread=SimpleThreadPoolWorker-4][Class=com.pari.nm.modules.upload.UploadHandler][Method=sendFile][line=96][upload_to_backend_preference xml =
<UploadToBackendPreference><UploadViaTransportGateway>false</UploadViaTransportGateway><UploadViaConnectivity>false</UploadViaConnectivity><TailEndOpenInternetFlag>false</TailEndOpenInternetFlag><UploadType>UploadUsingHttp</UploadType><UploadViaHttp>true</UploadViaHttp><UploadURL>/InvProcessMgr/rs/VSEM/upload</UploadURL><UploadTimeoutInMilliSecs>5000</UploadTimeoutInMilliSecs><UploadRetryCount>1</UploadRetryCount></UploadToBackendPreference>
[ERROR] [2017-05-25 18:41:46,205] : [Thread=SimpleThreadPoolWorker-4][Class=com.pari.nm.modules.upload.UploadHandler][Method=sendFile][line=103][Settings Map = {UploadTimeoutInMilliSecs=5000, UploadURL=/InvProcessMgr/rs/VSEM/upload, UploadViaTransportGateway=false, UploadViaConnectivity=false, UploadViaHttp=true, TailEndOpenInternetFlag=false, UploadType=UploadUsingHttp, UploadRetryCount=1}
[ERROR] [2017-05-25 18:41:46,205] : [Thread=SimpleThreadPoolWorker-4][Class=com.pari.nm.modules.upload.UploadHandler][Method=sendFile][line=116][Feature Name:smartnet_total_care
[ERROR] [2017-05-25 18:41:46,205] : [Thread=SimpleThreadPoolWorker-4][Class=com.pari.nm.modules.upload.HttpTransportIfImpl][Method=sendFile][line=256][java.net.ConnectException: Connection refused
[ERROR] [2017-05-25 18:41:46,205] : [Unable to send the profile results to the Cisco Backend. Reason:java.net.ConnectException: Connection refused
[ERROR] [2017-05-25 18:41:46,205] : [Thread=Thread-13][Class=com.pari.nm.modules.alertsystem.AlertManager][Method=addAlert][line=102][No Alert/Event subscribers found
Solved! Go to Solution.
06-15-2017 02:58 PM
Hello Yangdong,
I can see the uploads are still being received successfully from our end. I am working with our backend team to help make sure they get processed for you.
Thank you,
Jarrett
05-26-2017 05:26 AM
Hello There,
The CSPC will try to use the below address for issuing an upload to the backend. Can you please see if your firewall will allow traffic on this address?
IP: 72.163.7.113
Hostname: concsoweb-prd.cisco.com
Port: 443
Thank you,
Jarrett
06-09-2017 04:15 PM
I have confirmed the traffic not being blocked by the firewall. But I still cannot solve the problem.
06-15-2017 09:00 AM - last edited on 10-18-2017 01:35 PM by Cheri Fairbrother
Hello Jarrett,
Our last successful upload was back to June 6. And its processing ended up with failed in June 13. We were not able to upload anything since then. Would you please check?
And the following was the last successful one. Would you please help to clean any pending processes?
Yangdong
06-15-2017 02:58 PM
Hello Yangdong,
Thank you,
Jarrett
