updateDBScript.sh link broken
stimmerman
I have to use the updateDBScript.sh script to remove a hung 'Apply-in-progress' but the link to box isn't working for me.
The link in this PDF or this page does not work.
Does anyone have a correct link or can otherwise share the script?
Please PM me your email and I can see if I can send you the files.
Thanks!
11 Replies 11
Dannis Bounvilay
Can you see if you can access the files from the link below.
https://cisco.app.box.com/s/g67mnxzynzsqb1a2fofyc44rhuf9hr7w
Thanks!
Thanks for reaching out, but the link doesn't work.
Can't access it with my own Box account, or in a private browser session with my Cisco credentials.
Is it possible to share it via WeTransfer?
Thanks!
Can you send the script to me as well?
rtanap
I have this issue now. can some one share the script. Thanks.
Hi ,
I am the in-charge of this post and I will be assisting you you on this issue shortly .
Thanks & Regards,
Kapil Taneja
Hi kaptanej,
Thanks. Please kindly assist. I am updating but the status is stuck in "apply-in-progress". I need the updateDBScript.sh so that I can kill the apply process and trigger update again
rtanap
Could you please try accessing the files from the link below:
https://cisco.box.com/s/78v6dp2ioho21tilj8xrhu5fl6x87alc
Thanks!
Hi Rak,
Thanks for sharing. how do I run the updateDBScript.sh?
Hi Rak,
No worries. Already ran the uupdateDBScript.s and the
cleanImproperPatch.sh. Im doing the manual upgrade now.
Thank you very much.
Sounds good, Thanks for the update!
