Upgrade from CSPC 2.7.4.2 to 2.7.4.3 stuck in initiate
Hi Guys, I´m trying to upgrade from 2.7.4.2 to 2.4.7.3 and is stucked on "initiated"  state since last friday (72 hours). Is there any recommendations?
Thanks!
I´m posting the solution here.
Acces via CLI.
check update ( to get the last update name)
admin# check update
Patch versions
    Version Number:         sp-30.0.4-3-0-lnx64
        Description:        Collector patch to upgrade to CSPC 2.7.4.3
        Required Versions:  sp-30.0.4-0-0-lnx64
        Optimal JeOS:       jeos-30.0.4-3-lnx64
        Reboot Needed:      Yes
        Restart Needed:     Yes
        Package Size:       168250017 bytes
        Contents:
          Component Name:   Rules Pack
            Version:        4.6
            Description:    4.6
          Component Name:   CSPC Base
            Version:        2.7.4.3
            Description:    CSPC 2.7.4.3
        Installable:        Yes
download [upgrade-name] (in this case the command was admin# download sp-30.0.4-3-0-lnx64)
show download (when you see that the upgrade has been already downlaod apply the patch)
admin# show download
        Version             : sp-30.0.4-2-0-lnx64
        Download Location   : /opt/LCM/tmp/sp-30.0.4-2-0-lnx64-package.zip
        Status              : Downloaded
        Start Time          : Dec/30/50498 00:15:20
        End Time            : Jul/12/2018 18:37:04
        Reason For Failure  : -
        Version             : sp-30.0.4-3-0-lnx64
        Download Location   : /opt/LCM/tmp/sp-30.0.4-3-0-lnx64-package.zip
        Status              : Downloaded
        Start Time          : Mar/14/50682 02:01:29
        End Time            : Sep/17/2018 18:13:07
apply [upgrade-name]
then you can usse show apply to check if it was installed correctly
admin# show apply
        Version Number     : sp-30.0.4-2-0-lnx64
        Status             : Applied
        Start Time         : Jul/12/2018 18:37:36
        End Time           : Jul/12/2018 19:05:53
        Version Number     : sp-30.0.4-3-0-lnx64
        Status             : Applied
        Start Time         : Sep/18/2018 10:14:59
        End Time           : -
6 Replies 6
deogill
Are you upgrading using the LCM method or from the software tab on the webgui? Also have you tried restarting the collector and then restarting the upgrade?
Thanks and Best Regards,
HI deogil, I didn´t try restaring the collector, let me do it and reply you back with the result.
I´ve reload the box, but the upgrade is still in initate status.
Do you happen to have cli or console access to the collector. It might be best to upgrade the collector via the LCM method.
after a lot of times runnning the download and apply, seems that this time it is applying the patch. Let you know the result.
Thanks!
admin# show apply
        Status             : Applied
        Status             : Apply-in-progress
        End Time           : -
Acces via CLI.
admin# check update
Patch versions
        Reboot Needed:      Yes
        Restart Needed:     Yes
        Contents:
            Version:        4.6
            Description:    4.6
            Version:        2.7.4.3
        Installable:        Yes
        Status              : Downloaded
        Status              : Downloaded
admin# show apply
        Status             : Applied
        Status             : Applied
        End Time           : -
