upload automatic failed
Alexandre11
Hello, we did a recent and successful upload today but under the Upload Processing, we cannot see the latest upload.
15 Replies 15
balaji.bandi
check the logs as per the below post :
https://community.cisco.com/t5/smart-net-total-care-portal-and/upload-fails/m-p/3945774
BB
I did the procedures, did the collection and upload again, but still not showing in cisco smart net total care.
Alexandre11
Any news about this case ?
Thanks.
I added two pieces of equipment in the Cisco Collector, one with the 10.72.xx network and the other with the 10.73.xx network, made the collection and upload in the Cisco collector, and accessed the STNC to see if the two hosts appear and only 10.73 appears. xx o 10.72.xx does not appear on the STNC portal
I would suggest to wait for some TAC to reply, thiscould be some one need to look your account.
BB
In deploying the  image  you would have created the cli admin password?  (java based shell THE USER admin is not the same as the one from GUI and password may not be the same)
If so have you also created/activated  the users collectorlogin and root ? (real linux shell)
If not do the following for the cli admin  shell
admin# pwdreset root 90
And
admin# pwdreset collectorlogin 90
it will activate those accounts and generate their passwords  ( keep them where you can refer to them in the future)
after that
Via SSH Login to collector as user collectorlogin and then use command below to connect as root (cannot connect directly)
# su root
and then execute the following commands :
Please send me the output  in Private message
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
Also send me the following screenshot from your web collector application
[root@localhost collectorlogin]# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
223: 0.0.0.0: Mar 05 2020 11:19:02.806 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=116][isRemote=false]: message: *********** Sending message id:248848497957773
224: 0.0.0.0: Mar 05 2020 11:19:02.810 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : file_location Value : /opt/cisco/ss/adminshell/applications/CSPC/exportdata/sntc1x_VSEM_1583417864697.zip
225: 0.0.0.0: Mar 05 2020 11:19:02.829 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : feature_name Value : smartnet_total_care
226: 0.0.0.0: Mar 05 2020 11:19:02.831 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_type Value : file-message
227: 0.0.0.0: Mar 05 2020 11:19:02.832 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_id Value : 248848497957773
228: 0.0.0.0: Mar 05 2020 11:19:02.838 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : CustomerId Value : COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA
229: 0.0.0.0: Mar 05 2020 11:19:02.844 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : application_id Value : SCT4CGKGH2Y2MGPYQLJPXGAO1S0
230: 0.0.0.0: Mar 05 2020 11:19:02.844 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : AppServiceName Value : SNTC
231: 0.0.0.0: Mar 05 2020 11:19:02.851 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : reply_to_queue_name Value : ie.connectivity.outbound.queue
232: 0.0.0.0: Mar 05 2020 11:19:02.852 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : upload_applianceid Value : CSP0009043822
233: 0.0.0.0: Mar 05 2020 11:19:02.859 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : InventoryName Value : Copacol Inventario
234: 0.0.0.0: Mar 05 2020 11:19:02.859 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cPartyId Value : 4548579
235: 0.0.0.0: Mar 05 2020 11:19:02.860 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : ApplianceId Value : CSP0009043822
236: 0.0.0.0: Mar 05 2020 11:19:02.862 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : customer_id Value : 4548579
237: 0.0.0.0: Mar 05 2020 11:19:02.863 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : transport_mode Value : HTTPS
238: 0.0.0.0: Mar 05 2020 11:19:02.864 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cco_id Value : Alexandre11@@
239: 0.0.0.0: Mar 05 2020 11:19:02.864 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=499][isRemote=false]: message: uploadFileILB...
240: 0.0.0.0: Mar 05 2020 11:19:23.792 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=640][isRemote=false]: message: Send File successeded,http status:OK
241: 0.0.0.0: Mar 05 2020 11:19:23.800 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=646][isRemote=false]: message: HTTP Response:200
242: 0.0.0.0: Mar 05 2020 11:19:23.822 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=652][isRemote=false]: message: HTTP String:
243: 0.0.0.0: Mar 05 2020 11:19:23.900 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-20][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=127][isRemote=false]: message: Request ID :248848497957773 Execution completed. Sending Response
244: 0.0.0.0: Mar 05 2020 11:45:22.700 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=81][isRemote=false]: message: *********** Recieved Request for upload id:250428919643272
245: 0.0.0.0: Mar 05 2020 11:45:22.977 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=84][isRemote=false]: message: anyFeatureName=smartnet_total_care;CustomerId=COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA;application_id=SCT4CGKGH2Y2MGPYQLJPXGAO1S0;AppServiceName=SNTC;upload_applianceid=CSP0009043822;InventoryName=Copacol Inventario;cPartyId=4548579;ApplianceId=CSP0009043822;customer_id=4548579;cco_id=Alexandre11@@;fileLocation=/opt/cisco/ss/adminshell/applications/CSPC/exportdata/sntc1x_VSEM_1583419452342.zip
246: 0.0.0.0: Mar 05 2020 11:45:22.989 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=116][isRemote=false]: message: *********** Sending message id:250428919643272
247: 0.0.0.0: Mar 05 2020 11:45:22.996 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : file_location Value : /opt/cisco/ss/adminshell/applications/CSPC/exportdata/sntc1x_VSEM_1583419452342.zip
248: 0.0.0.0: Mar 05 2020 11:45:23.002 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : feature_name Value : smartnet_total_care
249: 0.0.0.0: Mar 05 2020 11:45:23.002 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_type Value : file-message
250: 0.0.0.0: Mar 05 2020 11:45:23.002 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_id Value : 250428919643272
251: 0.0.0.0: Mar 05 2020 11:45:23.002 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : CustomerId Value : COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA
252: 0.0.0.0: Mar 05 2020 11:45:23.007 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : application_id Value : SCT4CGKGH2Y2MGPYQLJPXGAO1S0
253: 0.0.0.0: Mar 05 2020 11:45:23.007 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : AppServiceName Value : SNTC
254: 0.0.0.0: Mar 05 2020 11:45:23.007 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : reply_to_queue_name Value : ie.connectivity.outbound.queue
255: 0.0.0.0: Mar 05 2020 11:45:23.008 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : upload_applianceid Value : CSP0009043822
256: 0.0.0.0: Mar 05 2020 11:45:23.008 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : InventoryName Value : Copacol Inventario
257: 0.0.0.0: Mar 05 2020 11:45:23.008 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cPartyId Value : 4548579
258: 0.0.0.0: Mar 05 2020 11:45:23.011 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : ApplianceId Value : CSP0009043822
259: 0.0.0.0: Mar 05 2020 11:45:23.011 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : customer_id Value : 4548579
260: 0.0.0.0: Mar 05 2020 11:45:23.011 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : transport_mode Value : HTTPS
261: 0.0.0.0: Mar 05 2020 11:45:23.012 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cco_id Value : Alexandre11@@
262: 0.0.0.0: Mar 05 2020 11:45:23.017 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=499][isRemote=false]: message: uploadFileILB...
263: 0.0.0.0: Mar 05 2020 11:45:44.389 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=640][isRemote=false]: message: Send File successeded,http status:OK
264: 0.0.0.0: Mar 05 2020 11:45:44.390 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=646][isRemote=false]: message: HTTP Response:200
265: 0.0.0.0: Mar 05 2020 11:45:44.445 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=652][isRemote=false]: message: HTTP String:
266: 0.0.0.0: Mar 05 2020 11:45:44.449 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-19][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=127][isRemote=false]: message: Request ID :250428919643272 Execution completed. Sending Response
267: 0.0.0.0: Mar 05 2020 11:47:17.032 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=81][isRemote=false]: message: *********** Recieved Request for upload id:250545867392417
268: 0.0.0.0: Mar 05 2020 11:47:17.057 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=84][isRemote=false]: message: anyFeatureName=smartnet_total_care;CustomerId=COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA;application_id=SCT4CGKGH2Y2MGPYQLJPXGAO1S0;AppServiceName=SNTC;upload_applianceid=CSP0009043822;InventoryName=Copacol Inventario;cPartyId=4548579;ApplianceId=CSP0009043822;customer_id=4548579;cco_id=Alexandre11@@;fileLocation=/opt/cisco/ss/adminshell/applications/CSPC/uploaddata/_UPLOAD/235_1/transport-inventory-1583419585467.zip
269: 0.0.0.0: Mar 05 2020 11:47:17.057 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=116][isRemote=false]: message: *********** Sending message id:250545867392417
270: 0.0.0.0: Mar 05 2020 11:47:17.057 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : file_location Value : /opt/cisco/ss/adminshell/applications/CSPC/uploaddata/_UPLOAD/235_1/transport-inventory-1583419585467.zip
271: 0.0.0.0: Mar 05 2020 11:47:17.058 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : feature_name Value : smartnet_total_care
272: 0.0.0.0: Mar 05 2020 11:47:17.058 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_type Value : file-message
273: 0.0.0.0: Mar 05 2020 11:47:17.058 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_id Value : 250545867392417
274: 0.0.0.0: Mar 05 2020 11:47:17.058 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : CustomerId Value : COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA
275: 0.0.0.0: Mar 05 2020 11:47:17.058 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : application_id Value : SCT4CGKGH2Y2MGPYQLJPXGAO1S0
276: 0.0.0.0: Mar 05 2020 11:47:17.059 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : AppServiceName Value : SNTC
277: 0.0.0.0: Mar 05 2020 11:47:17.059 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : reply_to_queue_name Value : ie.connectivity.outbound.queue
278: 0.0.0.0: Mar 05 2020 11:47:17.059 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : upload_applianceid Value : CSP0009043822
279: 0.0.0.0: Mar 05 2020 11:47:17.059 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : InventoryName Value : Copacol Inventario
280: 0.0.0.0: Mar 05 2020 11:47:17.059 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cPartyId Value : 4548579
281: 0.0.0.0: Mar 05 2020 11:47:17.060 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : ApplianceId Value : CSP0009043822
282: 0.0.0.0: Mar 05 2020 11:47:17.060 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : customer_id Value : 4548579
283: 0.0.0.0: Mar 05 2020 11:47:17.060 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : transport_mode Value : HTTPS
284: 0.0.0.0: Mar 05 2020 11:47:17.060 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cco_id Value : Alexandre11@@
285: 0.0.0.0: Mar 05 2020 11:47:17.060 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=499][isRemote=false]: message: uploadFileILB...
286: 0.0.0.0: Mar 05 2020 11:47:19.895 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=640][isRemote=false]: message: Send File successeded,http status:OK
287: 0.0.0.0: Mar 05 2020 11:47:19.896 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=646][isRemote=false]: message: HTTP Response:200
288: 0.0.0.0: Mar 05 2020 11:47:19.896 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=652][isRemote=false]: message: HTTP String:
289: 0.0.0.0: Mar 05 2020 11:47:19.897 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-17][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=127][isRemote=false]: message: Request ID :250545867392417 Execution completed. Sending Response
290: 0.0.0.0: Mar 05 2020 12:02:56.917 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=81][isRemote=false]: message: *********** Recieved Request for upload id:251482264518228
291: 0.0.0.0: Mar 05 2020 12:02:57.334 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=84][isRemote=false]: message: anyFeatureName=smartnet_total_care;CustomerId=COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA;application_id=SCT4CGKGH2Y2MGPYQLJPXGAO1S0;AppServiceName=SNTC;upload_applianceid=CSP0009043822;InventoryName=Copacol Inventario;cPartyId=4548579;ApplianceId=CSP0009043822;customer_id=4548579;cco_id=Alexandre11@@;fileLocation=/opt/cisco/ss/adminshell/applications/CSPC/exportdata/sntc1x_VSEM_1583420502877.zip
292: 0.0.0.0: Mar 05 2020 12:02:57.345 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=116][isRemote=false]: message: *********** Sending message id:251482264518228
293: 0.0.0.0: Mar 05 2020 12:02:57.355 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : file_location Value : /opt/cisco/ss/adminshell/applications/CSPC/exportdata/sntc1x_VSEM_1583420502877.zip
294: 0.0.0.0: Mar 05 2020 12:02:57.360 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : feature_name Value : smartnet_total_care
295: 0.0.0.0: Mar 05 2020 12:02:57.360 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_type Value : file-message
296: 0.0.0.0: Mar 05 2020 12:02:57.367 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : message_id Value : 251482264518228
297: 0.0.0.0: Mar 05 2020 12:02:57.368 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : CustomerId Value : COPACOL COOPERATIVA AGROINDUSTRIAL CONSOLATA
298: 0.0.0.0: Mar 05 2020 12:02:57.368 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : application_id Value : SCT4CGKGH2Y2MGPYQLJPXGAO1S0
299: 0.0.0.0: Mar 05 2020 12:02:57.368 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : AppServiceName Value : SNTC
300: 0.0.0.0: Mar 05 2020 12:02:57.369 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : reply_to_queue_name Value : ie.connectivity.outbound.queue
301: 0.0.0.0: Mar 05 2020 12:02:57.369 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : upload_applianceid Value : CSP0009043822
302: 0.0.0.0: Mar 05 2020 12:02:57.370 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : InventoryName Value : Copacol Inventario
303: 0.0.0.0: Mar 05 2020 12:02:57.370 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cPartyId Value : 4548579
304: 0.0.0.0: Mar 05 2020 12:02:57.370 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : ApplianceId Value : CSP0009043822
305: 0.0.0.0: Mar 05 2020 12:02:57.371 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : customer_id Value : 4548579
306: 0.0.0.0: Mar 05 2020 12:02:57.374 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : transport_mode Value : HTTPS
307: 0.0.0.0: Mar 05 2020 12:02:57.374 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=lambda$uploadFile$0][lineNumber=122][isRemote=false]: message: Caller Properties : Key : cco_id Value : Alexandre11@@
308: 0.0.0.0: Mar 05 2020 12:02:57.379 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=499][isRemote=false]: message: uploadFileILB...
309: 0.0.0.0: Mar 05 2020 12:03:19.897 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=640][isRemote=false]: message: Send File successeded,http status:OK
310: 0.0.0.0: Mar 05 2020 12:03:19.898 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=646][isRemote=false]: message: HTTP Response:200
311: 0.0.0.0: Mar 05 2020 12:03:19.906 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=652][isRemote=false]: message: HTTP String:
312: 0.0.0.0: Mar 05 2020 12:03:19.912 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp663450018-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.rest.TailEndRestApi][methodName=uploadFile][lineNumber=127][isRemote=false]: message: Request ID :251482264518228 Execution completed. Sending Response
313: 0.0.0.0: Mar 05 2020 19:25:55.461 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-3][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=63][isRemote=false]: message: Start Processing SSO_AUTH_QUERY :Message Id:-689710169: Start TimeStamp:1583447155387
314: 0.0.0.0: Mar 05 2020 19:25:55.999 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-3][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=63][isRemote=false]: message: Start Processing PUBLISH_MESSAGE :Message Id:-689710169: Start TimeStamp:1583447155999
315: 0.0.0.0: Mar 05 2020 19:25:56.396 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-3][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.jms.PublishJMSMessageCommand][methodName=execute][lineNumber=122][isRemote=false]: message: Response sent...
316: 0.0.0.0: Mar 05 2020 19:25:56.396 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-3][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=132][isRemote=false]: message: End Processing PUBLISH_MESSAGE :Message Id:-689710169 End Time:1583447156396 Time Taken:0 sec.
317: 0.0.0.0: Mar 05 2020 19:25:56.396 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-3][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=132][isRemote=false]: message: End Processing SSO_AUTH_QUERY :Message Id:-689710169 End Time:1583447156396 Time Taken:1 sec.
318: 0.0.0.0: Mar 05 2020 19:26:00.217 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-5][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=63][isRemote=false]: message: Start Processing SSO_AUTH_QUERY :Message Id:562828771: Start TimeStamp:1583447160217
319: 0.0.0.0: Mar 05 2020 19:26:00.236 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-5][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=63][isRemote=false]: message: Start Processing PUBLISH_MESSAGE :Message Id:562828771: Start TimeStamp:1583447160236
320: 0.0.0.0: Mar 05 2020 19:26:00.244 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-5][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.jms.PublishJMSMessageCommand][methodName=execute][lineNumber=122][isRemote=false]: message: Response sent...
321: 0.0.0.0: Mar 05 2020 19:26:00.244 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-5][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=132][isRemote=false]: message: End Processing PUBLISH_MESSAGE :Message Id:562828771 End Time:1583447160244 Time Taken:0 sec.
322: 0.0.0.0: Mar 05 2020 19:26:00.245 -0300: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=outbound_queue_listener_container-5][className=com.cisco.ca.csp.conn.gateway.core.GatewayCommandExecutor][methodName=execute][lineNumber=132][isRemote=false]: message: End Processing SSO_AUTH_QUERY :Message Id:562828771 End Time:1583447160245 Time Taken:0 sec.
[root@localhost collectorlogin]# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
CONNECTED(00000003)
depth=2 C = BM, O = QuoVadis Limited, CN = QuoVadis Root CA 2
verify error:num=19:self signed certificate in certificate chain
Certificate chain
0 s:/C=US/ST=CA/L=San Jose/O=Cisco Systems, Inc./CN=concsoweb-prd.cisco.com
i:/C=US/O=HydrantID (Avalanche Cloud Corporation)/CN=HydrantID SSL ICA G2
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
1 s:/C=US/O=HydrantID (Avalanche Cloud Corporation)/CN=HydrantID SSL ICA G2
i:/C=BM/O=QuoVadis Limited/CN=QuoVadis Root CA 2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2 s:/C=BM/O=QuoVadis Limited/CN=QuoVadis Root CA 2
MIIFtzCCA5+gAwIBAgICBQkwDQYJKoZIhvcNAQEFBQAwRTELMAkGA1UEBhMCQk0x
GTAXBgNVBAoTEFF1b1ZhZGlzIExpbWl0ZWQxGzAZBgNVBAMTElF1b1ZhZGlzIFJv
b3QgQ0EgMjAeFw0wNjExMjQxODI3MDBaFw0zMTExMjQxODIzMzNaMEUxCzAJBgNV
BAYTAkJNMRkwFwYDVQQKExBRdW9WYWRpcyBMaW1pdGVkMRswGQYDVQQDExJRdW9W
YWRpcyBSb290IENBIDIwggIiMA0GCSqGSIb3DQEBAQUAA4ICDwAwggIKAoICAQCa
GMpLlA0ALa8DKYrwD4HIrkwZhR0In6spRIXzL4GtMh6QRr+jhiYaHv5+HBg6XJxg
Fyo6dIMzMH1hVBHL7avg5tKifvVrbxi3Cgst/ek+7wrGsxDp3MJGF/hd/aTa/55J
WpzmM+Yklvc/ulsrHHo1wtZn/qtmUIttKGAr79dgw8eTvI02kfN/+NsRE8Scd3bB
rrcCaoF6qUWD4gXmuVbBlDePSHFjIuwXZQeVikvfj8ZaCuWw419eaxGrDPmF60Tp
+ARz8un+XJiM9XOva7R+zdRcAitMOeGylZUtQofX1bOQQ7dsE/He3fbE+Ik/0XX1
ksOR1YqI0JDs3G3eicJlcZaLDQP9nL9bFqyS2+r+eXyt66/3FsvbzSUr5R/7mp/i
Ucw6UwxI5g69ybR2BlLmEROFcmMDBOAENisgGQLodKcftslWZvB1JdxnwQ5hYIiz
PtGo/KPaHbDRsSNU30R2be1B2MGyIrZTHN81Hdyhdyox5C315eXbyOD/5YDXC2Og
/zOhD7osFRXql7PSorW+8oyWHhqPHWykYTe5hnMz15eWniN9gqRMgeKh0bpnX5UH
oycR7hYQe7xFSkyyBNKr79X9DFHOUGoIMfmR2gyPZFwDwzqLID9ujWc9Otb+fVuI
yV77zGHcizN300QyNQliBJIWENieJ0f7OyHj+OsdWwIDAQABo4GwMIGtMA8GA1Ud
EwEB/wQFMAMBAf8wCwYDVR0PBAQDAgEGMB0GA1UdDgQWBBQahGK8SEwzJQTU7tD2
A8QZRtGUazBuBgNVHSMEZzBlgBQahGK8SEwzJQTU7tD2A8QZRtGUa6FJpEcwRTEL
MAkGA1UEBhMCQk0xGTAXBgNVBAoTEFF1b1ZhZGlzIExpbWl0ZWQxGzAZBgNVBAMT
ElF1b1ZhZGlzIFJvb3QgQ0EgMoICBQkwDQYJKoZIhvcNAQEFBQADggIBAD4KFk2f
BluornFdLwUvZ+YTRYPENvbzwCYMDbVHZF34tHLJRqUDGCdViXh9duqWNIAXINzn
g/iN/Ae42l9NLmeyhP3ZRPx3UIHmfLTJDQtyU/h2BwdBR5YM++CCJpNVjP4iH2Bl
fF/nJrP3MpCYUNQ3cVX2kiF495V5+vgtJodmVjB3pjd4M1IQWK4/YY7yarHvGH5K
WWPKjaJW1acvvFYfzznB4vsKqBUsfU16Y8Zsl0Q80m/DShcK+JDSV6IZUaUtl0Ha
B0+pUNqQjZRG4T7wlP0QADj1O+hA4bRuVhogzG9Yje0uRY/W6ZM/57Es3zrWIozc
hLsib9D45MY56QSIPMO661V6bYCZJPVsAfv4l7CUW+v90m/xd2gNNWQjrLhVoQPR
TUIZ3Ph1WVaj+ahJefivDrkRoHy3au000LYmYjgahwz46P0u05B/B5EqHdZ+XIWD
mbA4CD/pXvk1B+TJYm5Xf6dQlfe6yJvmjqIBxdZmv3lh8zwc4bmCXF2gw+nYSL0Z
ohEUGW6yhhtoPkg3Goi3XZZenMfvJ2II4pEZXNLxId26F0KCl3GBUzGpn/Z9Yr9y
4aOTHcyKJloJONDO1w2AFrR4pTqHTI2KpdVGl/IsELm8VCLAAVBpQ570su9t+Oza
8eOx79+Rj1QqCyXBJhnEUhAFZdWCEOrCMc0u
Server certificate
subject=/C=US/ST=CA/L=San Jose/O=Cisco Systems, Inc./CN=concsoweb-prd.cisco.com
issuer=/C=US/O=HydrantID (Avalanche Cloud Corporation)/CN=HydrantID SSL ICA G2
No client certificate CA names sent
SSL handshake has read 5660 bytes and written 589 bytes
New, TLSv1/SSLv3, Cipher is AES256-SHA
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : AES256-SHA
Session-ID: F93F0E3078F52C2E98CDFD3254207CD3EA54E575F9ABBBE1E34EE71A9ED88484
Session-ID-ctx:
Master-Key: 5E6627E54075016BBD73C6D6DF5E03615550044EBDEBAC89FB66087C6C3B4935BAD2FFD3C9D44D2243510AD144113D82
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 300 (seconds)
TLS session ticket:
0000 - be 5a 1d b3 82 0c 0f e6-3c 9b 4d 45 5f a8 ce 5a .Z......<.ME_..Z
0010 - f9 f3 4a 39 28 37 e1 ed-4e 05 98 d4 be fa c8 d0 ..J9(7..N.......
0020 - c0 ac ae b1 c4 81 c1 8f-c5 45 97 8d 83 68 9d 60 .........E...h.`
0030 - 88 74 c8 68 dd c4 cb 95-af 15 30 0e 96 fc aa 2f .t.h......0..../
0040 - 3f 29 62 69 c4 a3 94 e9-ec 0b 3d 3f c4 ff 00 8c ?)bi......=?....
0050 - bd 8c 27 3f ea 5a 98 f4-f2 e1 7e 8e 84 1c 17 53 ..'?.Z....~....S
0060 - ff d1 a5 71 1e ec 2b 1b-4a 8f fa 37 e7 9b fe c8 ...q..+.J..7....
0070 - d2 b1 5b 7e ed 87 1f fc-fb 46 97 e6 77 dd a6 e6 ..[~.....F..w...
0080 - e0 e8 7a 75 bc c7 1d de-b7 fb 85 6c 8b 36 60 ae ..zu.......l.6`.
0090 - 37 d8 76 9e 00 cc 96 13-58 8d 5a 38 30 1e 1c 2c 7.v.....X.Z80..,
00a0 - f6 1c 33 2a f2 42 49 0d-91 37 52 33 f4 11 c5 da ..3*.BI..7R3....
00b0 - f7 fa cd 78 13 95 2a 3d-b4 49 82 83 2b 30 f4 aa ...x..*=.I..+0..
Start Time: 1583452172
Timeout : 300 (sec)
Verify return code: 19 (self signed certificate in certificate chain)
[root@localhost collectorlogin]# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
2020-03-05 12:02:57,369 ==== thread: qtp663450018-23 ==== INFO >
connectivityteg.lambda$uploadFile$0() => (line: 122)
2020-03-05 12:02:57,370 ==== thread: qtp663450018-23 ==== INFO >
2020-03-05 12:02:57,371 ==== thread: qtp663450018-23 ==== INFO >
2020-03-05 12:02:57,374 ==== thread: qtp663450018-23 ==== INFO >
2020-03-05 12:02:57,379 ==== thread: qtp663450018-23 ==== INFO >
connectivityteg.uploadFileILB() => (line: 499)
TimeStamp set in the token - 1583420577387. Nonce set in the token - 3460523155145611184
TOKEN IS - BJnVaplb2QCKtAwEC0NSNiIJTyA=
2020-03-05 12:03:19,897 ==== thread: qtp663450018-23 ==== INFO >
connectivityteg.uploadFileILB() => (line: 640)
2020-03-05 12:03:19,898 ==== thread: qtp663450018-23 ==== INFO >
connectivityteg.uploadFileILB() => (line: 646)
2020-03-05 12:03:19,906 ==== thread: qtp663450018-23 ==== INFO >
connectivityteg.uploadFileILB() => (line: 652)
2020-03-05 12:03:19,912 ==== thread: qtp663450018-23 ==== INFO >
connectivityteg.uploadFile() => (line: 127)
GatewayCommandInvoker.....com.cisco.ca.csp.conn.gateway.core.command.CommandSelectionHelper@2e773509
GatewayCommandInvoker commandObjectcom.cisco.ca.csp.conn.gateway.core.CommandObject@515b5313
2020-03-05 19:25:55,461 ==== thread: outbound_queue_listener_container-3 ==== INFO >
connectivityteg.execute() => (line: 63)
GatewayCommandInvoker commandObjectcom.cisco.ca.csp.conn.gateway.core.CommandObject@5384e2eb
2020-03-05 19:25:55,999 ==== thread: outbound_queue_listener_container-3 ==== INFO >
2020-03-05 19:25:56,396 ==== thread: outbound_queue_listener_container-3 ==== INFO >
connectivityteg.execute() => (line: 122)
connectivityteg.execute() => (line: 132)
GatewayCommandInvoker commandObjectcom.cisco.ca.csp.conn.gateway.core.CommandObject@39f90468
2020-03-05 19:26:00,217 ==== thread: outbound_queue_listener_container-5 ==== INFO >
GatewayCommandInvoker commandObjectcom.cisco.ca.csp.conn.gateway.core.CommandObject@88abb8b
2020-03-05 19:26:00,236 ==== thread: outbound_queue_listener_container-5 ==== INFO >
2020-03-05 19:26:00,244 ==== thread: outbound_queue_listener_container-5 ==== INFO >
2020-03-05 19:26:00,245 ==== thread: outbound_queue_listener_container-5 ==== INFO >
[root@localhost collectorlogin]# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
--2020-03-05 20:51:26-- https://72.163.7.113/HeadEndWebAppServlet/
Connecting to 72.163.7.113:443... connected.
WARNING: certificate common name “concsoweb-prd.cisco.com” doesn't match requested host name “72.163.7.113”.
HTTP request sent, awaiting response... 302 Found
Location: https://cloudsso.cisco.com:443/as/authorization.oauth2?response_type=code&client_id=wam_prod_ac&redirect_uri=https%3A%2F%2F72.163.7.113%2Fpa%2Foidc%2Fcb&state=eyJ6aXAiOiJERUYiLCJhbGciOiJkaXIiLCJlbmMiOiJBMTI4Q0JDLUhTMjU2Iiwia2lkIjoiOGEiLCJzdWZmaXgiOiJ... [following]
--2020-03-05 20:51:26-- https://cloudsso.cisco.com/as/authorization.oauth2?response_type=code&client_id=wam_prod_ac&redirect_uri=https%3A%2F%2F72.163.7.113%2Fpa%2Foidc%2Fcb&state=eyJ6aXAiOiJERUYiLCJhbGciOiJkaXIiLCJlbmMiOiJBMTI4Q0JDLUhTMjU2Iiwia2lkIjoiOGEiLCJzdWZmaXgiOiJpRVJ...
Resolving cloudsso.cisco.com... failed: Temporary failure in name resolution.
wget: unable to resolve host address “cloudsso.cisco.com”
The uploads for this collector is not failing  but they are being silenced. too many uploads in the same day and time( and likely more than one source)
Please send me screen shots as I requested of the COLLECTION profile and not of the UPLOAD profile
HERE ARE the backend information as we are receiving these uploads, but they will not be processed correctly until scheduller process is fixed.
SILENCED CSP000XXXXX22 2020-03-05 15:05:50 UTC 2020-03-05 15:06:03 UTC None Collector Upload None None
581709887 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-05 14:49:50 UTC 2020-03-05 15:16:53 UTC 2020-03-05 15:41:26 UTC Collector Upload INCREMENTAL INCREMENTAL
581706603 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-05 14:48:18 UTC 2020-03-05 15:11:34 UTC 2020-03-05 15:21:21 UTC Collector Upload INCREMENTAL INCREMENTAL
581703410 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-05 14:21:54 UTC 2020-03-05 14:46:08 UTC 2020-03-05 14:59:24 UTC Collector Upload INCREMENTAL INCREMENTAL
581703843 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-05 13:54:49 UTC 2020-03-05 14:19:31 UTC 2020-03-05 14:26:13 UTC Collector Upload INCREMENTAL INCREMENTAL
581706411 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-05 13:51:41 UTC 2020-03-05 14:14:33 UTC 2020-03-05 14:24:34 UTC Collector Upload INCREMENTAL INCREMENTAL
581639891 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-04 21:28:03 UTC 2020-03-04 22:11:11 UTC 2020-03-05 00:47:05 UTC Collector Upload INCREMENTAL INCREMENTAL
581639871 VSEM COPXXXXXX SUCCESS CSP000XXXXX22 2020-03-04 21:02:47 UTC 2020-03-04 21:46:08 UTC 2020-03-05 00:38:21 UTC Collector Upload FULL FULL
YOU MAY DELETE THE PREVIOUS LOGS AND SCREENSHOTS AS THEY MAY HAVE CUSTOMER PRIVATE INFORMATION
Okay. I can send.
Tell me what are the tabs and where should I go to access them?
PLEASE USE the instructions above.
I don't know about instructions above. I don't know about cisco collector, I am new in that Can you help me please ?
:) you no longer that new Alexandre I already dealt with you a number of times.:)  what I need is the screen shots of the collection profile as I mentioned on the post above.  It shows where to click and what to get. particularly ---> Settings-- Manage Dta COLLECTION profile---> (CLICK ON THE PROFILE twice) --> profile details.get the whole screen likely you need to split it into two images.
Profile details attached.
