Upload CSPC
anderson.1
Could you please provide support and guidance because the Collection upload has been failed.
See attached picture message error `Inventory Operation Failed`
7 Replies 7
jofrumki
Please go to the Job Run Status page and look for the most recent Miscellaneous job which should be the upload portion of the collection job you ran. Select View Job Logs and send a screenshot of the error, you should have to right click on the exception row to view the full message.
Screenshot attached.
Thank you, can you please send a screenshot from the following location on the GUI;
Administration->Server Properties->Server Properties tab
Also, if you are able to login to the CLI as root please run the command;
df -h
Files attached.
Based on the Server Properties you have deployed the CSPC Ultra Small ova. I would redeploy the CSPC Small instead which uses 4 CPU, 4G RAM, and 200G HDD. This should resolve the upload issue.
I have only 25 devices on the network. Is the upgrade to the small version valid while the Ultra Small holds up to 5000 devices?
The error seen in the upload logs indicates that the CSPC does not have enough space to write to disk. Please disregard the recommendations seen while deploying for now and deploy the CSPC Small .
