Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
6620
Beginner
Account locked due to 7 failed logins
I can not SSH to CSPC 2.7 after a new install and password change.
Do I need to reinstall the server to get it working again?
1 ACCEPTED SOLUTION
Try to use the following user and password after a 30 minute period.
admin
Adm!23min
If you haven't changed the password it should work.
11 REPLIES 11
With the new CSPC 2.7 image, if up to 3 failed login attempts have occurred back to back, it will temporarily lock the account for 30 minutes.  Can you please try and see if you're able to login after a 30 minute period?
Thank you,
Jarrett
Beginner
Same result after 1 hour wait
Same result after 1 hour wait time. Attaching screenshot. Admin usr works as expected on the web browser.
Highlighted
Hello OTRAdvisory,
Hello OTRAdvisory
  Did you manage to solve the problem?
I am facing the same issue as yours now
Beginner
No answer or solution
No answer or solution provided yet. Still can not login through SSH.
Hello, can you please post a
Hello, can you please post a screenshot of any error messages you receive?
In addition, what ssh client are you using?
Does the behavior repeat for all users? - admin/collectorlogin ??
Cesar
I couldn't login using users
I couldn't login using users "admin" or "admin123", "root" and "collectorlogin" are not enabled yet.
I am trying from vSphere console and ssh using putty
admin
Adm!23min
I have reinstalled the ova
I have reinstalled the ova and I can now login using admin and collector login accounts but I have a problem with root user is locked for more than 24 hrs.
I need to unlock it to be able to extract the collector file manually to upload it to Cisco portal.
Beginner
Password is not what is
Beginner
Re: Hello,
I have a similar issue, I waited for more than 30 minutes and I'm still locked...
When you say "if you haven't changed the password", are you talking about the WEB interface admin account or the ssh account?
Does the web interface and the shell share the same accounts?
Re: Hello,
Hi Steve,
For tracking and to allow visibility to your request we ask that you start a new discussion.  Our experts can help from there.
Cheri
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
