04-25-2017 10:30 AM
A customer would like to know if it's possible to change the AES 128-bit data encryption to AES 256-bit instead while transferring data from CSPC to Cisco Backend.
It's a security requirement for them.
Marcus
04-27-2017 06:27 AM
Hey guys, any idea about this issue?
04-27-2017 06:41 AM
Hello, we've inquired with the CSPC team to provide an update regarding the latest details (CSPC 2.7).
We're pending their response.
We'll update you as soon as we hear back!
Cesard
05-02-2017 06:02 AM
Cesar, how is going?
Thanks a lot for your help.
Do you have any answer from them?
Marcus
05-02-2017 06:09 AM
Good morning Marcus,
I am pending an official update from the security team. It looks like new documentation is under review and will be posted when it's ready. However, I believe that the latest CSPC uploads using 256-bit encryption, pending official documentation to confirm this.
Cesar
05-10-2017 06:27 AM
Cesar,
Thanks a lot for your help!
Were you able to confirm it? Do you have the official documentation link?
Marcus
05-16-2017 12:16 PM
Hello Cesar, how is going?
Do you have an update for this question?
Marcus
05-18-2017 07:58 AM
Hello Marcus,
We have engaged with the security team, however no ETA has been provided for an updated document. I am following up and trying to get an official response.
Cesar
05-29-2017 08:11 AM
I have accessed SSH session on CSPC 2.7 and got the following:
openssl s_client -connect concsoweb-prd.cisco.com:443
New, TLSv1/SSLv3, Cipher is AES128-GCM-SHA256
Server public key is 1024 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : AES128-GCM-SHA256
Then, It's still using AES128... Now I am wondering that if it's possible to change it manually or not?
If you have any suggestion I will be glad to hear.
Marcus
06-16-2017 10:11 AM
Hey guys, how is going?
Do you have any answer for it?
Marcus
05-16-2017 02:06 PM
Hi all
I need to confirm if the CSPC has support to sha-256 over SSH and GUI sessions to management purposes and for connection to Cisco Cloud. Do you know?
Best regards,
Marcos Valente.
