Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
393
Highlighted
Beginner
Affected Devices Count is incorrect
Under Active Alerts in SNTC, I am getting disparate counts for actual devices where an alert would be applicable.
For example, in the first screenshot (Active Alerts - 6907) I have a count far larger than devices in my network.  In the second screenshot (Drill Down - 3433), that count is cut immediately in half without any filtering.  This count is still bigger than the number of applicable devices.  In the third screenshot (Chassis - 703), I finally get an accurate count for what is affected.
What needs to be done to get this these numbers properly aligned?
My thanks in advance for any and all help that can be offered.
EDIT: This issue appears to be germane mostly to Software EoX Alerts.  Hardware EoX mostly appear to be correct (router switchcards appear to be the exception).  PSIRTs are being addressed by a bug.
Everyone's tags (1)
8 REPLIES 8
Highlighted
Hello James,
Hello James,
I see the difference in the count of affected devices reported, will be analyzing the issue further and get back with the findings.
Regards, Suchita
Highlighted
Beginner
Wanted to check in to see if
Wanted to check in to see if there has been any movement on this issue.  Are we the only client that has reported this kind of discrepancy?
Highlighted
Hello James,
Hello James,
We created a bug to address this issue. The bug number is CSCve49943. You can track this on the Bug Search Tool : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCve49943
Highlighted
Beginner
Can I inquire if this bug
Can I inquire if this bug also covers the issue that;
The numbers reported in "Notification from Cisco Smart Services - Alert Processing" emails differs to that within SNTC alerts reports?
So far I have yet to find any count that matches; generally they are close +/- 10% but they should be 100% accurate, especially where the inventory or alerts haven't changed.
Rgds, Graham
Highlighted
Beginner
Re: Hello James,
Wanted to check in again to see if there has been any movement on this issue.  I've seen nothing altered for CSCve49943 since it was acknowledged in May of this year.
Highlighted
Beginner
Highlighted
Re: Affected Devices Count is incorrect
Hi James,
We have raised the issue with our development team. Please continue to watch the bug for progress.  There currently is no scheduled timeframe for a fix to be deployed.
Cheers,
Cheri
Highlighted
Beginner
I've yet to see any movement on CSCve49943.  Wanted to check and see if there is a timeline to get this addressed
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
