Hi team,
Can you please let me know if there is a way to set up PSIRT alerts to be sent to an email when new ones are listed rather than manually having to log into the SmartNet Total Care portal?
a customer of mine tries to grant me access to his SNTC but is not able to.
The error message is:
If the checkbox for the role is not selectable the user is not a reseller of any of your company's Smart Net Total Care contracts and cannot be r...
This upgrade patch is stuck in prgress. for over a week. How to stop and restart?
Version Number : sp-30.0.4-2-0-lnx64 Status : Apply-in-progress Start Time : Jul/24/2018 12:59:17 End Time : -
Eu estou com problema com o CSP implantado em hyper-v versão 2.7 , as informações subiram para o portal porem o cliente possui 20 equipamentos , e no portal ficou mais que duplicado os equipamentos.
Estou com problemas na base de um cliente.
O inventário tem part numbers que se repetem até 6 vezes e outros que não aparecem nenhuma vez.
O que pode estar acontecendo?
Alguém já teve este problema e conseguiu solucionar?
After upgrading the CSPC frm 2.6 to 2.7 I am unable to gain console access to the CSPC appliance via SSH . When I log in, credentials for the "admin" account are accepted and then the following is displayed:
[collectorlogin@lipmngcsc01 ~]$ su ...
Buenos días,
Estoy teniendo problemas con un cliente debido a que el collector no descubre 6 switches del siguiente modelo:
4 son modelo Cisco DS-C9124-K92 son modelo Cisco DS-C9148S-K9
El cliente me dice que ya tienen configurado la comunida...
By mistake I have created another instance of SNTC database but it doesn't have any devices imported yet. To avoid confusion I would like to delete this duplicate instance. How it can be done?
Sandeep Khera
Our access switches are covered under [Product ID - Unique Serial#] setup.Ex:Product ID: WS-C3750X-48P-SQuantity: 10Unique Serial Number: FDO1111111** 10 C3750X are covered under this unique serial number.
Hi all!
I have the most recent version of CSPC just installed. Everything works fine. But I needed to check some proxy related stuff via CLI, and noticed that I am unable to access with admin user, the session just close over and over.
I am able to...
