I have added new devices to my upload profiles. It says the upload job has completed successfully but I still do not see the new devices populating in the portal. Please assist
Buenos días
Para el cliente Colmedica no se tiene acceso al CSAM debido a que esta creado actualmente como External Role Administrator. Acudo a ustedes para que por favor nos ayuden cambiando el perfil a Internal Administrator.
Our collector status has been in "Upload in Progress" for several days now. Also, when new collections are done I don't see those uploads show up? We are on CSPC 2.7 . What other information can I provide?
hi, need to know where to clear filter in smart care portal, i recently filter by a serial number in the contracts area, since then i only see the switch filtered out, even if i logout-login to the portal...
I have a customer that is looking to implement the collector for SNTC but they had a question that I don't know the answer to. They asked if they were to perform a code upgrade on a device that isn't covered under SmartNet, would it throw up a red f...
Hello
I have a customer who does not have information about his switches (EoL, if its contract is expired, etc). Can I use the SNTC collector to get this inventory, even from devices that do not have SNTC contract?
Thank you
Marcos
Im struggling to understand what the difference is between the TrueView report and the Contract Summary Detail report provided by Cisco, can anyone help?
I'm trying to upgrade the CSPS from 2.7 to 2.7.1. When I click on the UI to Install it fails every time on the download. Since that is only status gives is Download Failed.
So I would like to try the upgrade via CLI but I can not find the software o...
On August 1st I updated the collector, but in the snt portal the information still appears not updated, I reviewed the upload Processing and the status int the portal appears status success
Appliance needs fsck ran but needs lost root password, it will just continue to reboot and fail the file check. It was set up in 2014, before my time at the company, and no one knows the password. I get no other option to log in as admin or collector...
In my company, we have 2 collectors. Each collector is meant to update different inventories. However, since I’m not responsible for both collectors it is possible that the other collector is collecting the same device(s) as my collector.
Can you...
Within the SNTC portal, I’ve opted to set my reporting preference to LATEST view. However, when I’m looking at my reports, such as Custom Inventory Report, I notice that several collection dates are shown. Why does that happen?
Thanks!
