I put up a second collector version 2.7 and the collection process seems to run fine until the upload then i get a failed message.
I would like some help figuring this out.
We activated the SNTC portal and the collection of information with the CSPC 2.7 on a vmware environment. We have activated various collector with several customers but with this one we are having a lot of issues.
1. We can't have a SUCCESFUL up...
I have not gotten a clear answer on this. The portal is a great help with Service Coverage Management specifically around vidibility, and I know that the admin can create role based access control to allow specific users visibility to specifi...
Aloha All
We have a question on setting up the inventory in CSPC & SNTC, use an test upload to SNTC that had some devices on the network, now we setup CSPC Collector 2.7 and it collected all the devices on the network that has some if the same device...
Hi Team
You may find your collector type is changed to CNC since 7/July , however due to backend logic change, it's not the right value for your dedicate collectors.
We have raise the bug to get it fix as soon as possible.
If you have any queri...
I have a Collector detecting correctly two DS-C9148-K9-SUP, but it doesn't know who is the DS-C9148S-K9-SUP.
Thanks in advance for your help.
Miguel
Hi guys
I've installed cisco smart collector around 6 times in the past however on this occasion, once i install the OVA file in vmware and then try to add a static ip address when the server boots up I get a "configuring your cspc appliance" and t...
We have just deployed the CSPC 2.7 VM in our network. The basic IP, gateway config is done via CLI and upon first GUI login, we are getting the install wizard page. However, the settings like DNS, NTP, Timezone etc. are not successful at all. We are ...
My collector is starting to get cluttered with discovery jobs and the portal upload processing list is also pretty cluttered. I was just wondering if there was an easy way to organize or remove items from these specific lists or any other lists in ge...
The report shows chassis and other modules but not the 6800 sup cards. The report also shows 6500, 4500, Nexus sup cards. Antone had any luck with 6800 sup cards ?
For Party ID: 1645***, there was a CSV upload last week. There is a serial covered back in January 2017 that is showing uncovered on the portal. CCWR, My Devices and CSCC show otherwise. Can you confirm why SNTC is showing incorrect information?
P...
Hello, Johns Hopkins University has begin to use the SNTC Portal. They just registered and discovered that their company name is wrong. It should read Johns Hopkins University. It reads Hopkins John University.
This seems to be an error in the en...
Is there a reason why an item that our customer says is no longer online would be showing up in the portal? I have confirmed that they are looking at the latest data rather than comprehensive and am seeing the same information in their portal when I...
