08-21-2019 09:29 AM
I did a csv file import for a customer of some spare devices and gave them unique hostnames of spare-1, spare-2 and so on. However, I gave them all the same IP address of 1.1.1.1. That was probably the cause of my issue. The upload worked, but it gave all devices the same hostname and made the first one the parent and all the rest children. It also showed one serial # as blank. I can't seem to figure out how to delete the inventory and try again. Or if I upload it again with changes to the IP's, will it overwrite?
Solved! Go to Solution.
08-21-2019 10:25 AM
Yes, correct. That'll be best (scheduled uploads) unless you require the details now, you can run a manual collection/inventory and upload from the CSP Collector.
Reference the CSPC User guide for more info. https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-User-Guide.pdf
Br,
Walt
08-21-2019 09:46 AM
Please refer to > Inventory Deletion found in our SNTC User guide https://www.cisco.com/c/en/us/support/docs/services/sntc/portal_user_guide.html
Br,
Walt
08-21-2019 09:54 AM
The only option under inventory deletion is the entire inventory, not just the file import. If I delete it, I assume I'll have to wait for their new discovery to run this weekend to re-populate?
08-21-2019 10:25 AM
Br,
Walt
