Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
120
Beginner
Can a file import be deleted to retry?
I did a csv file import for a customer of some spare devices and gave them unique hostnames of spare-1, spare-2 and so on.  However, I gave them all the same IP address of 1.1.1.1.  That was probably the cause of my issue.  The upload worked, but it gave all devices the same hostname and made the first one the parent and all the rest children.  It also showed one serial # as blank.  I can't seem to figure out how to delete the inventory and try again.  Or if I upload it again with changes to the IP's, will it overwrite?
1 ACCEPTED SOLUTION
Re: Can a file import be deleted to retry?
Yes, correct. That'll be best (scheduled uploads) unless you require the details now, you can run a manual collection/inventory and upload from the CSP Collector.
Reference the CSPC User guide for more info. https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-User-Guide.pdf
Br,
Walt
3 REPLIES 3
Please refer to > Inventory Deletion found in our SNTC User guide https://www.cisco.com/c/en/us/support/docs/services/sntc/portal_user_guide.html
Br,
Walt
Beginner
The only option under inventory deletion is the entire inventory, not just the file import.  If I delete it, I assume I'll have to wait for their new discovery to run this weekend to re-populate?
Br,
Walt
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
