Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
409
Highlighted
Can we mix mandatory and optional field entries for file import?
Can we have devices with mandatory fields only and some other devices with mandatory and optional fields within the same CSV file used for file import?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Beginner
Hi Rita and Sandra,
That is correct, you can mix mandatory and optional field entries for file import. However, if you don’t have OS type and version, the alerts matching would be impacted.
June
2 REPLIES 2
Highlighted
Beginner
I think you can. I have seen sample files with both.
Highlighted
Beginner
Hi Rita and Sandra,
June
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
