06-25-2018 07:38 AM - edited 03-12-2019 07:51 AM
I already created a new inventory to generate a new certificate called Collector. teste but when i went to option File Import, the new invenotry name do not appear?
Can someone plz help .
Solved! Go to Solution.
06-25-2018 12:14 PM - edited 06-25-2018 12:14 PM
Inventory names will not auto populate from your collector names. You will have to manually input the inventory name (make sure it matches what you set on the collector).
Regards.
Regards.
