Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
Collector on customer has normal boot process interrupted by auditd daemon that shows the following messages:
audit: backlog limit exceeded
After that, we have a prompt to enter in single mode user, Give root password for maintenance or CTRL + D to continue, but if we give CTRL + D to continue we have the boot interrupted again showing the same audit messages, as explained earlier.
As result collector is offline now.
Thanks in advance.
Luciano.
Solved! Go to Solution.
Ola Luciano Please mark this post as answered/resolved.
I seems to be a Kernel Panic where likely he has deployed the wrong specs for CSPC SNTC, please request the present specs on the VM.. additionally it seems that the panic is caused by a catch 22. there is is no enough resources causes the collector to create logs, kern.log and messages log gets the harddrive to 100% usage. Please send the specs in which he has deployed this collector. for verification.
As predicted that is what happened as far as resources and 100% hard drive usage. Those specs (tiny) are not supported for the SNTC service. so It had the behaviour I mentioned. That specs is only to be used as a single iteration Transaction engagement typically for another service (BCS)
For SNTC It must be at least the small version. there is not enough storage or memory or cpu for the SNTC service. He will need to redeploy.
To deploy the collector on the Vmware Esxi host, configure the network and set the CLI passwords as per attached document.
In deploying it will ask the size of the network that will provide the requirements and automatically configure the ova to that requirement, based on my experience the best suited for your network will be to choose at least the Small (10K devices) deployment for good performance . If possible select a higher option for better performance
thank you what is the link of the Guide you mentioned? For me to verify. To be more clear if this is the GUIDE you mention
The collector itself is multi-service and used across the organization. Some services may be able to use that light spec so it is a valid for the collector. But it is the service that determined the requirement for the specs. To be fair with you that light collector is an exception and therefore confusing for reviewing the document and an enhancement request has been made to modify its nomenclature for only valid for transaction single iterations service only.
