Cisco Smart net total care problems
Hello Team, We just generated a new certificate and downloaded the entitlement. and we already uploaded the certificate int he collector. But already did a successful upload but the data is not reaching in the portal. Find attached a picture
7 Replies 7
jumin
Hey AlexandreOppermann,
Please private message me a screenshot of your upload profile settings.
Justin
A moment please.
Any news about this case ?
Can you please check your advanced settings for Upload Type and make sure it's set to Connectivity?   From your screenshot, I believe you are using an older method of uploading called Transport Gateway which is no longer supported.
If I change the option to connectivity it will fail and won't run in:
Settings - Application Settings - Export Settings
It's work now.
Thank you for the help.
