Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
1016
molinait
Beginner
Cisco UCS managed by the Collector
Hi!
It is possible that the Collector Appliance can manage the UCS devices?
Thanks!
3 REPLIES 3
Chris Camplejohn
Yes. You can add the UCSM (UCS Fabric Interconnect) to the CSPC. If you have any stand-alone UCS-C servers, you can individually add the CIMC interface IP.
Hi thanks for the quick response!
Can you provide me a guide or something like that to configure the SNMP on the UCSM and UCS-C servers?
CIMC Configuration
UCSM Configuration
The specifics could be different depending on which versions you are running.  Once you have SNMP enabled, you can add the devices to CSPC like you would any other router or switch.
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
