Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
943
Highlighted
Beginner
Collector Failed Connection to https //72.163.7.113 refused
Hello Team
Our Customer have installed a new collector because the old VM are gone and after register in SNTC Portal we can't send data collected to cloud.
That is the error message:
Medium Event Upload failed at 02/20/2018 15 03 05 BRT with the response
A connectivity exception occured while processing the request. The Exception is HTTPs TransportMode has Failed Connection to https //72.163.7.113 refused
Atached some screenshots
Any sugestion to what to do?
Thank you
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Collector Failed Connection to https //72.163.7.113 refused
Hello, this confirms you have no outbound connection.
Please verify your network settings and ensure that no blocks are in place preventing outbound access to the Cisco upload server
(concsoweb-prd.cisco.com:443)
Regards.
4 REPLIES 4
Hi there, please log into the command line as collectorlogin user and perform the following test.
Share the output once you obtain it.
curl --tlsv1.2 https://concsoweb-prd.cisco.com/HeadEndWebAppServlet/ -v -k
Beginner
[collectorlogin@cspc ~]$ curl --tlsv1.2 https://concsoweb-prd.cisco.com/HeadEndWebAppServlet/ -v -k
* About to connect() to concsoweb-prd.cisco.com port 443 (#0)
* Trying 72.163.7.113... Connection timed out
* couldn't connect to host
* Closing connection #0
curl: (7) couldn't connect to host
Regards.
Beginner
Because of the change of the customer topology, we configure another gateway and the connection was established.
Thank you for the support.
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
